Unread 08-17-2011, 03:39 AM   #1
bfreel1
my master bath renovation
When I started thinking about re-doing my master bath (I mean my wife started thinking about me re-doing the master bath) I started doing some research and I stumbled on this site. Thank goodness there is a wealth of information on this site. I have been lurking for about three weeks. I have gutted the bathroom down to bare studs, ripped out tile (which was laid directly over old tile, all cracked and grout falling out).
I have decided, due to this site, to do a Kerdi shower with a mud pan. I can't wait until the kerdi and the drain I ordered shows up. I have dry wall up in the shower, the curb is down.
A couple of questions-
1. Should I kerdi the walls before I tackle the mud pan and curb?
2. I am building the shower in what was a standard 32"x60" cove for a tub. I built a 5' high knee wall on the open side 26" long to hopefully eliminate the need for a shower curtain. Will the knee wall be a problem down the road since there is no floor to ceiling support on the one end of it? (I will post pictures tomorrow)
3. should I tile the rest of the bathroom before I do the mud pan also, or walls, mud pan, then remaining bathroom floor?
Any input would be greatly appreciated. thanks
eric
bfreel1 is offline   Reply With Quote
Unread 08-17-2011, 05:23 AM   #2
1) Yes.
2) It won't be a problem if you do the framing correctly. Without the ceiling connection, the top of such a wall will be flexible. The best you can do is to tie the end studs directly into the floor joists, rather that rely on the sill plate to be sturdy enough.
3) Do all the shower first, including the floor, then any bathroom walls, then the bathroom floor. You can do this in another order if scheduling pressures dictate, but this order helps prevent damage to your new work.
Unread 08-17-2011, 05:28 AM   #3
bfreel1
Thanks for the quick reply. Hopefully I get my kerdi products today so I can start. I did tie into the floor joists for the knee wall. I will try to start posting some pictures today. My wife got a new camera yesterday. Advice is much appreciated.
eric
Unread 08-17-2011, 10:57 PM   #4
bfreel1
What is the thinset of choice for applying the kerdi to the walls. I know un-modified, but is there a preferred brand?
I have HD, Low, and another local box store.
eric
Unread 08-18-2011, 02:19 AM   #5
bfreel1
bump
eric
Unread 08-18-2011, 02:27 AM   #6
Toddman
Independent Tile Contractor
Toddman's Avatar
I use Laticrete 317. Although it seems some Lowe's stores carry Laticrete, and some don't.
Todd
Good work is not cheap, and cheap work is not good.
http://www.toddthetileguy.com
Toddman is offline   Reply With Quote
Unread 08-18-2011, 02:54 AM   #7
bfreel1
Thanks Todd.
If I can't get the Lacticrete 317 is there something I could ask around for at some of the local tile shops? Or will they maybe have the Lacticrete?
eric
Unread 08-18-2011, 05:22 AM   #8
You can use Versabond from HD.
Unread 09-01-2011, 09:32 PM   #9
bfreel1
I have all the kerdi in and it looks great. We decided not to do a bench, but now that I have all the kerdi in my wife thinks she wants a small step in the corner. maybe a foot high is it too late since the kerdi is already in or can I build it right on the kerdi.
eric
Unread 09-01-2011, 09:36 PM   #10
bfreel1
Also, We want to put some shelves in the same corner for shampoo and soap. I am not sure about the premade ones matching is there a good way I can make them out of the tile I am using? If I just us a single tile the cut edge will look like crap. Is there a way to do this with a good outcome?
eric
Unread 09-02-2011, 12:07 AM   #11
bfreel1
any ideas
eric
Unread 09-02-2011, 09:30 AM   #12
bfreel1
bump
eric
Unread 09-02-2011, 11:00 AM   #13
Eric, type "corner shelf" into the Advanced Search feature and ask for Titles. Try other terms, too.
You'll find lots and lots of discussion about that.
Master Bath Renovation Acipenser Tile Forum/Advice Board 53 01-24-2012 02:59 PM
Gary's Master Bath Renovation gary@kevelson.com Tile Forum/Advice Board 6 10-20-2010 01:30 PM
Master Bath Renovation 8/1/09 iagaoe Tile Forum/Advice Board 11 08-11-2009 04:43 PM
Master Bath Renovation sm11030 Tile Forum/Advice Board 5 10-04-2007 08:50 PM
Major Master Bath Renovation Complete JayHill Tile Forum/Advice Board 3 03-06-2006 02:50 PM
