Unread 01-26-2009, 04:27 PM   #1
agstaff
Need Help with Starting Shower Tile
Greetings all,
I apologize in advance because I'm sure you've answered these questions a million times. Redoing the shower in the home I just bought. The bath/shower was tiled, but needless to say they didn't know what they were doing (tiles construction adhesived to drywall). Starting fresh from the tub up (down to studs). My plan so far is drop ceiling 10-12" above tub, install new drywall and an aftermarket tub surround, then tile above top of surround and on ceiling. Do I need a a vapor barrier? If so do I do felt paper or plastic? Would you vapor barrier over studs before drywall for surround as well? Will I still need to do hardibacker or wonderboard beneath tile as there will be no direct water on the tile, only vapor? Any help would be much appreciated.
agstaff is offline   Reply With Quote
Unread 01-26-2009, 05:28 PM   #2
johntrent
Welcome Agstaff - sorry to hear you are going with something other than tile for your surround - someone with more experience will most definitely chime in but I don't think you need a vapor barrier behind your fiberglass/plastic surround nor do you need cbu. No need for the vapor barrier above the tub or on the ceiling either.
John
johntrent is offline   Reply With Quote
Unread 01-26-2009, 06:58 PM   #3
agstaff
Thank you for your response John. I had contemplated tile but am concerned about maintenance, upkeep & cleaning. Fiberglass is an easy wipe down with lots of storage. I am not confident in my tiling ability to make it 100 percent watertight. Plus I know tile & grout is not waterproof to begin with. Plus this will be my first tile job so I'm thinking it will not be as fast as fiberglass.
Unread 01-26-2009, 07:39 PM   #4
Eric Bock
Give it a try Agstaff! I'm a cop and not even close to a skilled tile layer. I wanted to try it so I bothered the guys in here for a few months and they walked me through the entire process. I have included a picture of my first try. I think it came out great, and not just the tile I destroyed the entire bathroom, ceiling and all. If you have another bathroom that can be used while one is out of order, I would try it. Plus I had an estimate done and they wanted over $4000, I did it for way less and had extra money to buy better tile.
Eric Bock is offline   Reply With Quote
Unread 01-26-2009, 10:08 PM   #5
agstaff
Eric,
That looks great! Pretty much exactly what I was looking to do with the dropped ceiling, u even have a window like me too. Is there a reason you chose not to tile the ceiling? Is the ceiling just drywall? Any concerns with it being that low with steam?
Thanks, Andy
Unread 01-26-2009, 10:33 PM   #6
Eric Bock
I had plenty of support above so I used Durock instead of drywall. I was going to tile it but with two kids and a wife wanting use of the tub, I put a thin coat of joint compound and sanded it. Then I just primed and painted it. I have a strong fan just out of sight of the picture and if it gets too steamy I just crack the window.
Unread 01-27-2009, 12:30 AM   #7
Deckert
Theres no reason to worry about putting drywall in the ceiling of a conventional shower or tub-shower surround.
Project looks good Eric.
Brannigan
HeenanGC.com
Unread 01-27-2009, 08:56 AM   #8
agstaff
Thanks for the input Deckert, I could use all I can get. Glad to hear I can use drywall on the ceiling, way lighter than durock & easier to work with, for me anyway.
Even if the ceiling is dropped can I still do drywall?
If I decide to tile the ceiling can I attach tile to the drywall since there will be no direct water contact or should I upgrade to a tile backer product?
If anybody has any input what so ever I'm more than appreciative.
Thanks everbody!
Unread 01-27-2009, 09:11 AM   #9
You can use drywall on the dropped ceiling, tile or no tile. Portions of the walls and the ceiling above the shower head are conisdered outside the "wet area," so they don't need any special treatment.
Unread 01-27-2009, 10:00 AM   #10
agstaff
Thank you for everyone's help thus far. Basically it's sounding like I only need a tile backer where the tile is in direct contact with water in a conventional tub/shower (no steam), as tile & grout are porous and will transfer some water.
Andy
Unread 01-28-2009, 10:18 AM   #11
agstaff
CBU/Substrate Question
What is the cutoff point for the "wet area" in a standard tub/shower surround. I have been told that you can use drywall for anything about the shower head, including the ceiling.
I have also read that drywall/greenboard is no longer allowed anywhere in or above the tub area.
Which is correct? Can anyone give me any insite?
Andy
Unread 01-28-2009, 10:29 AM   #12
Dave Taylor
Dave Taylor's Avatar
Hi Andy.......
Drywall ABOVE the shower head (6" - 8") and on the shower ceiling is not frowned on by folks here-a-bouts' unless..... you have a steam or otherwise enclosed shower.
Green-board is no longer approved for use in wet areas.... period.
Not sure what you mean by "tub area" but...... if it's a tub surround your thinking of..... and the surround walls will get direct water spray or lots of splashing...... consider using Kerdi over drywall or CBU with some kind of vapor barrier.
Hope this helps
Dave T (DIY'er)
the net.
Unread 01-28-2009, 10:34 AM   #13
Welcome, Andy.
I've combined you with your original thread on this project. Please bookmark this one and use it for all your project questions so folks can see what you're working on and what's been previously asked and answered.
We can change the title to something more generic for you if you like.
Unread 01-28-2009, 11:18 AM   #14
agstaff
Dave,
Thanks for the input. When I say tub area I am referring to the 3 walls adjacent to the tub and the ceiling. No steam, just a standard 5' tub.
Do not plan on tiling up to and including ceiling. Just want to make sure that if I do decide to go back and tile to and including ceiling at later date and it's drywall, I will be ok and won't have to rip it out and install some form of CBU.
Andy
Unread 01-28-2009, 11:22 AM   #15
GB Tile
Great Britain Tile
GB Tile's Avatar
Ceiling
You will be fine with the drywall as long as it it is not a steam shower and the room has adequate ventilation.
GB Tile is offline   Reply With Quote
Shower with tile walls and prefab pan? Many questions Anna5 Tile Forum/Advice Board 10 02-04-2008 02:37 PM
Multi-room Multi-substrate Tile Job Jerry Wannabe Tiler Tile Forum/Advice Board 5 11-13-2007 11:47 PM
Starting a tile shower elliemaeisme Tile Forum/Advice Board 7 01-25-2005 06:29 PM
Starting to Tile the Shower (Yikes!) Crickett Tile Forum/Advice Board 13 05-31-2004 07:16 AM
Tile over old tile or remove old tile? Setter Wannabe Tile Forum/Advice Board 6 05-11-2004 11:59 AM
