Unread 12-13-2006, 06:48 AM   #1
bunt
Fiber tape for hardi?
I just finished installing ditra in the laundry, mbath, and guest bath. I had the ditra left over from the last job. Unfortunately, I have the foyer to do and I am out of ditra. I am planning on using hardi just because I can get it locally. Theres only about 5 sheets or so I need to install, but I am not looking forward to it,.....I think the ditra has spoiled me. In the past when I installed hardi, I put the tape on as I installed the hardi. This unfortunatley leaves a "hump" to deal with when tiling. Does anyone install the tape as their doing the tile? You know, comb out the thinset then lay the tape down before you set your tile. I wonder if this produces the same integrity as installing the tape directly to the hardi during installation?
.....Larry
bunt is offline   Reply With Quote
Unread 12-13-2006, 07:26 AM   #2
Splinter
Splinter's Avatar
Taping while tiling is the best way to do it... I believe most of the guys here do it this way...
Alex
Unread 12-14-2006, 12:06 AM   #3
Hi Larry,
Taping on the fly is how I do it, too.
But have you checked your local Home Depot for Ditra? Not all, but some including the stores by me, are stocking small rolls of Ditra. Or you could always contact Tile Experts for whatever amount you need. They are more than happy to do that for you.
Unread 12-14-2006, 04:49 AM   #4
SteveG91
Tile Man -- Oakland, CA.
Whenever I used to tape on the fly, too many times would I forget to tape then what, lift up tile-tape and recomb etc......or try to not forget anymore....... the other thing is when I remember, what to do at straight edge????? either have tape hanging over or end it at straight edge, then start a new piece....so many interruptions in tape what's the point of taping then????????? so now, ( well actually now it's usually ditra!!!!! but same principle on walls ) I tape before tiling and sponge down the thinset till it's almost non-existent (so no hump) and figure when I tile the new thinset will bond to tape and it'll be fine. Just how I do it........
Steve
SteveG91 is offline   Reply With Quote
Unread 12-14-2006, 07:31 AM   #5
bunt
Tool guy, hd by me does not stock ditra. However, I did see that "custom products" is making something similar to ditra called "easy mat". I wonder whether hd will start carrying this product since they carry their thinset and grout?
.....Larry
Unread 12-14-2006, 09:23 AM   #6
Splinter
Splinter's Avatar
Hmmmm.. You remember to put on underwear each morning, dontcha?
Seriously, it's such an important step, so it's always on my mind.
I dont follow... Every seam gets covered with tape as I tile... Can you explain the problem with a little more detail for us slow folks?
Alex
Unread 12-14-2006, 09:28 AM   #7
Skibumm
I am getting ready to tape and would love a once over on how exactly you guys do it. I percieve that I will lay a bit of mud down lay down tape and then screed with a flat trowel or spackle knife. Is it just like drywall but with different mud?
Greg Anderson
Skibumm is offline   Reply With Quote
Unread 12-14-2006, 09:52 AM   #8
bunt
I believe most who tape during tiling simply put the tape over the joint, press it down, then thinset over it (while forcing a bit of thinset in gap), then set your tile.
.....Larry
