Unread 07-24-2021, 07:15 AM   #1
ohliuw
CBP unmodified thinset and Kerdi
My first time doing kerdi shower base. I usually use the LFT CBP thinset with large tiles, but I followed the Kerdi instructions to use unmodified.
I usually mix the mortar the way I like to work with, but this time I decided to follow the instructions on the bag, which said 5.7 litres per bag.
I am not sure if there is a typo, but I could not even mix it properly - my drill wouldn’t even spin - so I added extra 0.5 litres and managed to somehow mix it. It ended up very hard to work with, I was barely able to set the shower pan and to install the Kerdi corners, then had to throw out the rest (I was planning to lay the tiles at the same time, which obviously didn’t happen). So my 2 questions are:
1. Why the recommended ratio didn’t work for me? Should I go by feeling when I lay the floor tiles?
2. Kerdi says to use unmodified thinset, but on the curb and on the walls at the bottom where I have the Kerdi band I need to use 4x24 tiles, and the unmodified thinset is only good til 15”, so what thinset I use for those?
Cleo
ohliuw is offline   Reply With Quote
Unread 07-24-2021, 07:57 AM   #2
What unmodified thinset mortar from Custom did you use, Cleo?
Unread 07-24-2021, 08:00 AM   #3
Lazarus
Lazarus's Avatar
Probably Customblend. Only unmodified they generally stock. Worst stuff I've ever seen...
Mapai makes a good, unmodified morter.
Laz
Unread 07-24-2021, 08:31 AM   #4
ohliuw
This one:
https://www.homedepot.ca/product/cus...-kg/1000173400
Cleo
Unread 07-24-2021, 08:50 AM   #5
That mortar is no longer available south of the 39th parallel, Cleo. When it was available, it was the only useful unmodified mortar in the Custom line. Not great, perhaps, but usable.
There have been times when we've found serious discrepancies in the printed instructions on the bags of thinset mortars, particularly in the amount of water required. I cannot say that's what you're dealing with there, but you might check the bag instructions against the most current online published specs.
There are thinset mortars that require more mixing time than you would expect and those times are in the instructions. That should not be the case with an unmodified mortar, though, unless I'm seriously out of touch.
We (TYW) strongly recommend reading and following manufacturer's installation instructions, but there are times when it makes sense to deviate from those instructions a bit. Schluter's requirement for unmodified mortars for use with their membranes is one such time in my opinion. Custom's VersaBond works quite well with Schluter's membranes and any other similar membranes. Indeed, all other membrane manufactures require the use of a modified mortar meeting ANSI A118.4 (check your ISO equivalent).
Unread 07-24-2021, 10:38 AM   #6
ohliuw
Thanks, will use Versabond for the tiling. I hope the base and the membrane will be ok with the one I used.
Cleo
Unread 07-24-2021, 10:42 AM   #7
Are you going to perform a flood test before tiling?
Unread 07-24-2021, 01:42 PM   #8
Mixing thinset needs to do several things:
- evenly wet all of the components
- help to break up any smaller particles so it's smoother.
SO, while evenly wetting all of the components in a modified is critical, it can really help even with an unmodified.
FWIW, you need a fairly hefty drill motor to mix a full bag of thinset, regardless of the type. It's important to use the recommended speed, and many smaller drill motors can't turn at those speeds if the load it too high.
If you want a really good example of how mixing time makes a huge difference, try Latticrete's one with some pulverized rubber in it (helps with sound attenuation)...it looks like it will never come together, and then, poof, magic, all of a sudden, it's nice and smooth. Messes it up if you add extra water at the beginning because you think it's too dry.
Used regular unmodified mortar not thinset on kerdi TCS Tile Forum/Advice Board 9 05-06-2019 02:16 PM
kerdi and unmodified thinset danxp Tile Forum/Advice Board 7 11-10-2012 08:49 AM
Kerdi, unmodified thinset and Water pwa Tile Forum/Advice Board 6 07-20-2008 08:46 AM
Thinset for Kerdi, modified or unmodified? jalge2 Tile Forum/Advice Board 6 05-19-2008 11:12 AM
kerdi shower - unmodified thinset both layers? thenewguy Tile Forum/Advice Board 6 05-28-2006 08:06 PM
