Unread 03-24-2014, 11:21 PM   #1
cruisin_n_style
Hardie > Kerdi > Porcelain Tile - Thinset?
In my shower I have HardieBacker up on the walls. I am putting up the Kerdi membrane to waterproof it. And I have porcelain tile going on top of the Kerdi. My question is, what thinset should I use #1: between the hardiebacker and the Kerdi? And #2: between the Kerdi and the porcelain tile?
From what I gather modified thinset mortar is recommended on hardiebacker. However, unmodified thinset is recommended under Kerdi. So which one should be used? (And I understand that unmodified doesn't need air to dry, and modified does).
Also, from what I gather modified thinset mortar is recommended for installing porcelain tile. However, unmodified is recommended over Kerdi. So again, which should be used here? (And yes I know good quality thinset should be used Laticrete, SpectraSet, TEC, etc).
I'm just confused since I'm sandwiching two products which each recommend a different thinset. Hardie to Kerdi and then again with Kerdi to porcelain.
Craig
cruisin_n_style is offline   Reply With Quote
Unread 03-24-2014, 11:34 PM   #2
Use a premium unmodified thinset on both the Hardie and to set the tile...
The Hardie is VERY thirsty, and to avoid having issues with it pulling all of the moisture out of the thinset before you can embed the Kerdi to it, you MUST wipe the Hardieboard down...more than once doesn't hurt. You don't want it dripping, but you do want it wet before you spread the thinset. A mistake newbies make with Kerdi is they try to use too big of a sheet until they get the hang of it.
The bond to a porcelain tile with an good unmodified is in the order of 250-300psi, which means to tear a 12x12 tile off the wall is 10's of tons, once it is set...the tile won't come off. The thinset itself doesn't stick to Kerdi, but if it is mixed properly, when you embed the membrane, it encapsulates the fleece, and once cured, it is locked fully in place. But, don't rush it...thinset doesn't attain its stated full strength for 28-days...and, if you try to peel it back, you will be able to for a few days. Pulling a tile off would be very tough, since you'd be trying to pull the whole sheet off at once, not a very thin line if you're peeling it back.
The other thing you should do is to peel a section back immediately after you put it up to verify proper coverage. If you mixed the thinset properly, and the Hardie wasn't too dry, or you didn't get it up fast enough, you'll see the back of the Kerdi fully covered with thinset as well as the wall. If you got that, it will go back on the wall really easily. Then, you know you have the technique and can consider larger sheets, but I'd still not try to wrap a full sheet around the shower!
If you can get it, DitraSet mortar is really nice, but there are others around that work well. Do NOT use an entry level (i.e., cheap, mostly sand) dryset mortar. A good one will cost you in the order of $15-25, depending on where you buy it, and what kind of discount you can get, if any.
Unread 03-24-2014, 11:53 PM   #3
pfmez
Welcome Craig.
What Jim said. If you're worried about using unmodified thinset on porcelain, page 36 of the Schluter shower system handbook has a pretty good write up about it. I recently put up Kerdi for the first time using Ditraset mortar, and not that I'm experienced with thinsets, its seems really awesome to me, I paid about $25 a bag with tax.
A couple things I learned (which I wish would have been on a practice piece!), definitely work in small pieces, I did entire walls in one piece, and man I wish I had split it in two! While you should be in a hurry from the first thinset on the wall to the time you place the kerdi, definitely spend some time embedding it, this is where I went wayyy too fast, once the kerdi is there you have plenty of time to embed it, make sure all the ridges are down and its nice and flat, especially at corners and seams where you will have kerdi band adding to the build up.
I would highly recommend doing a small practice piece first, to get the feel for it and how the thinset mix will work, mine was too stiff in retrospect. A helper would have also been nice!
Fred
pfmez is offline   Reply With Quote
Unread 03-24-2014, 11:53 PM   #4
cruisin_n_style
Awesome, thanks for the prompt responses.
Craig
Unread 03-25-2014, 10:30 AM   #5
Ditraset instructions have a range of water to use...to embed Kerdi, go towards the high end. When setting tile on Ditra, depends on the situation, lower end for big, heavy tile, probably middle for normal sized tile. It should be creamy, not peanut butter, closer to mayonnaise and when you spread it out, it still needs to be able to hold the notch without flowing level. If you stick your finger in, it should cover your finger, but not drip off. If you just get a depression in the pot, it's way too thick, or has started to set.
Unread 11-23-2014, 07:53 PM   #6
cruisin_n_style
How to tile/trim outside corner transition
I have been adding a second bathroom area in my house and have recently run into a situation I can't seem to think of the answer by myself. If I could get some advice it would be appreciated. I have a walk in curbed shower entry and a partition wall (which the water lines run through). The curb and inside of the entry will be tiled...however I intend for the outside of the partition wall to be finished and painted drywall. The issue is that the entryway and curb meet along with the non tiled partition wall and I am unsure how to protect the edges of the tile and transition everything properly at the edges and corners. It is much easier to show than it is to explain so I will attach a photo. I thought about using some type of J-channel but then where the wall meets the curb that wouldn't work right. Please take a look. (Just note, I still have a piece of cement board to put over the wood stud on the end of the partition wall, and none of the drywall is in place yet either, i simply put a scrap piece up to give an idea. Also, the Kerdi membrane will be used over the cement board and curb.)
How do I tile over the curb and inside the entryway, yet still have a nice seamless edge along the painted drywall all the way to the curb and even past the curb to the floor? I have my nice porcelain tile purchased but all the nifty edging and trim pieces are not available in my tile. They do have one type of bull-nose but I don't like it. Ideas? Links? Suggestions?
Craig
Unread 11-23-2014, 08:09 PM   #7
Welcome back, Craig. This the same shower you started a thread for back in March?
What treatment, if any, do you plan for the shower opening?
We can't see anything about the size or shape of your shower or the location of the shower head[s], but those bottom outside corners can be one of the first locations of failure in that kind of shower. Waterproofing and tiling around to the outside is a good idea, but not mandatory.
Unread 11-23-2014, 11:20 PM   #8
cruisin_n_style
Shower entry will be left open. The entire bathroom floor will be tiled. Right now I have heated floor element embedded in the SLC outside the shower. The shower itself is 4 ft by 4 ft. There will be only one shower head and it is spraying AWAY from the entryway towards the back wall. But may also end up being a large rainfall shower head in the center of the shower.
Would a good option be to tile the outside of the curb and continue that tile as a bottom border all the way around the bathroom? Then the only area I need to worry about is the Outside corner transition of the entryway where it is tiled over cement board on the inside and painted drywall outside. Suggestions how to treat this corner?
Also that styrofoam "curb" is just for reference...it was packaging leftover from something. That's where the curb will be though.
Craig
Unread 11-24-2014, 12:15 AM   #9
cpad007
hack of some trades
cpad007's Avatar
I'd tile around that outside corner if you think it would be aesthetically pleasing to you and Mrs. Craig.
CX is right, each corner/leg on my shower was trashed upon removal so it would be prudent to waterproof that area in some fashion.
Schluter has some nice profile edges (Quadec or Rondec...I'm using the Quadec) to clean up outside corners and terminate tiles in the middle of a wall.
I'll post some pics of them in my thread shortly.
Chris
DIYer-us Extrem-us Non-Pro-us
Chris' Orange Tile Project
cpad007 is offline   Reply With Quote
Unread 11-24-2014, 10:10 AM   #10
cruisin_n_style
Tiling around that vertical outside corner actually would not look good at all :-/ But my father suggested that as well. I guess as a last resort I could do that.
Craig
Unread 11-24-2014, 11:13 AM   #11
cpad007
hack of some trades
cpad007's Avatar
It looks like you have kind of a "column" going on there...might work. Would you mind taking a pic a few steps back? Give us a full view of the shower entry if ya don't mind.
Chris
Unread 11-24-2014, 11:25 AM   #12
Craig, I would recommend you waterproof and tile the floor outside that shower for at least a little ways. You will have some splash-out and best to protect it now while it's easy.
Unread 11-24-2014, 12:26 PM   #13
cruisin_n_style
I will waterproof a little ways out from the curb. Here is another photo, sorry it's sorta blurry. As I said, the drywall is not up on the outside of the wall yet, I just put a scrap piece there for reference. Also the styrofoam where the curb will be is a scrap piece for reference.
Craig
Unread 11-24-2014, 06:10 PM   #14
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I've done this with J-channel before, gotta do a little head scratching to get it all aligned and then just mud over the J channel when finishing drywall. I'd beef up that wall framing some.
Peter
inside corner trim - after tiling ? onycomosis Tile Forum/Advice Board 22 05-12-2009 02:40 PM
Tile to Sheetrock Transition in Outside Corner oreyes Tile Forum/Advice Board 2 09-24-2008 04:32 AM
Corner Trim Ideas pb1718 Tile Forum/Advice Board 1 07-16-2008 09:00 AM
Corner Trim Angle Bucket Head Tile Forum/Advice Board 2 02-28-2005 10:05 PM
Outside corner Paint/Tile transition walktall Tile Forum/Advice Board 3 11-27-2004 08:22 PM
