Unread 06-29-2013, 12:28 PM   #1
chefwong
3 Wall Shower - Drop in Tubs
For a standard 5' wide bathroom, with 3 walls, are drop in tubs allowed - taking into account it will also server as showers.
I read somewhere that the regular apron tubs with tile flange is the only tub for this sort of setup.
Waterproofing aside - tile install aside : can a drop in tub be used in this application with the intent that the front of the tub apron will be tiled over.
alan
chefwong is offline   Reply With Quote
Unread 06-29-2013, 12:32 PM   #2
dhagin
Yes it can be done, generally speaking. Not recommended though due to the extra waterproofing required and possibility of failure. Verify with the tub manufacturer and follow their instructions.
Post a link to the tub you have in mind.
dana
Unread 06-29-2013, 12:42 PM   #3
chefwong
I have not even looked at tubs.
In my head, as long as a proper flange (aka-Kerdi/Kerdi fix) was down between the tub and wall, any (tub) could be used as long as it fit the RO.
I may be wrong in making this assumption, hence the inquiry
The built in flange on the tub is the same thing. It's just done for you instead of you doing it yourself.
And, the Kerdi flange IMO will be a bigger seal (wider) than the built in flange..
alan
Unread 06-29-2013, 09:05 PM   #4
tileguynky
Koehler makes a drop in tub with flange, using two of them right now.. Don't have the model number in front of me, but want to say 1121-r should be it. We set the tub and the built a thin wall on the front of the tub so that the tiled face is flush with the edge of the tub.
Unread 06-30-2013, 03:44 PM   #5
chefwong
I was planning to just use Kerdi around the entire perimeter of the tub and addix with Kerdi Fix and attach to studs as my *flange*.
I did a brief look at tubs. Seems like the acrylics are deeper than CI. 21" H versus 17 1/2. Methinks the wifey would prefer the 17 1/2.
alan
Unread 06-30-2013, 04:55 PM   #6
chefwong
Greg -
BTW, great looking tile. Is that porcelin look-alike.
I've done some very minimal shopping. They all look to fake to me - both polished and unpolished....but hopefully, I stumble across the *one*
alan
Unread 06-30-2013, 05:02 PM   #7
Even with tile flanges on 3 sides, special attention needs to be paid where the flange stops and the skirt starts. That area we call the top of the tub leg and is a classic spot where leaks occur.
Can we make this work?...Drop in tub in a 3 wall alcove type installation? Reefgeek Tile Forum/Advice Board 11 07-30-2010 09:10 AM
drop in tub look with shower jjscavo Tile Forum/Advice Board 16 07-16-2010 12:18 PM
Wall tiling around a drop in tub Mummy Tile Forum/Advice Board 5 05-07-2010 05:51 AM
Drop in tub in 3 wall Alcove Kat Mac Tile Forum/Advice Board 4 05-24-2007 08:56 PM
Tiling the deck before/after drop-in tubs are installed Northwest Tile Guy Professionals' Hangout 13 08-22-2006 08:22 PM
