Unread 08-22-2014, 08:31 AM   #1
muskie36
Ceiling & Tub-line Caulk Color???
hi guys/gals,
new to forum and diy novice on tile work; obvious with the sad-sack simple question i am asking but know you can help.
just completely gutted two bathrooms to studs. finished tiling an alcove bath and a 3x5 seated shower stall with exception of caulking joints as last item. will be using 100% silicone to be on safest side even if overkill. after spending thousands on the projects i am not very concerned with those few extra dollars in cost for extra peace of mind. used kerdi board for all walls, and kerdi pan and seat for shower.
wall changes in plane will definitely be color-matched to my light smoke grout, but not sure if top and bottom caulk joints should also be color-matched on the tub project???
is it more professional, preferred, standard, expected for ceiling and tub-line joints to be color-matched or white when ceiling and/or tub are white???
i would appreciate any/all help you can give me on this.
thanking you in advance for your responses, kind regards,
muskie36
muskie36 is offline   Reply With Quote
Unread 08-22-2014, 08:44 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Changes of plane where tile meets tile, tub or pan get 100% silicone. I almost always use color matched acrylic caulk where tile interfaces with painted surface 'cuz paint doesn't stick to silicone (despite advertising hyperbole) which will bite someone's butt sooner or later...
Peter
Unread 08-23-2014, 12:42 AM   #3
Welcome to the forum, Brian.
Yeah, acrylic caulk at the painted ceiling interface. It's one of the only times I ever use the stuff. Otherwise, it's 100% silicone for most everything else.
As far as your question to 'which color?'...just run a 2" bead of each color at the tub and your particular situation with your particular tile with your particular lighting will make itself known which looks better.
Removal Old Grout & Caulk from Porcelain Tub Lukas711 Tile Forum/Advice Board 3 05-19-2008 04:06 PM
Shower ceiling & tub deck tom.m Tile Forum/Advice Board 8 04-02-2008 03:31 PM
(HELP) tub & tile caulk problem hemiless Tile Forum/Advice Board 11 03-23-2007 12:44 PM
Caulk & Thinset on tub DoofusOfTheDay Tile Forum/Advice Board 6 11-23-2005 06:57 AM
Tile Shower Stall - Grout/Caulk Ceiling & Floor twintwin Tile Forum/Advice Board 8 05-24-2005 07:11 AM
