Found usc_block_11 empty, added this: [CODE] [/CODE]
Old 07-11-2018, 08:52 AM   #1
ganch
Cat threw up on black marble
The cat could have barfed anywhere, but it picked the marble in front of my fireplace. I tried Superior brand poultice stain remover but it didn't do anything. The photo shows the hazy irregular circle that remains. Any idea on how I can get rid of it? Also open to suggestions on how to get rid of the cat, without my family killing me.
Ganch
ganch is offline   Reply With Quote
Old 07-11-2018, 04:20 PM   #2
Hi Ganch,
I think the marble might be slightly etched. Acid in the cat's stomach.
Old 07-11-2018, 06:08 PM   #3
I agree that the surface has been etched. This isn’t a stain that you’re dealing with. It's physical damage to the once smooth surface. Because the surface is microscopically rough, instead of smooth and glossy, the light refracts off it unevenly. And this greatly diminishes the color of the stone. It makes it look dull. The proper fix is to restore the rough surface to ultra smooth by grinding it with diamond polishing pads, starting with coarser grits and progressively using finer and finer grit pads. It’s not unlike sanding wood with sandpaper, continuously sanding with finer and finer sandpaper.
Only, there’s a catch. It’s kinda challenging to match the perfect factory gloss using little pads. It’s easy enough to get to a glossy surface, but it may not blend perfectly with the rest of the tile. It’s like when a car door is damaged and they go to paint...they aren’t going to apply the paint and clear coat layers to just the damaged spot....they will paint the whole door. Likewise, it might be easier to restore the whole tile. Or do the final polishing across all your tiles to unify the glossy sheen.
In order of easiest (for you) to most effort (and consequently the most expensive to the least expensive):
1) Hire a stone refinishing pro to restore the tile. They may end up polishing more tile than just the spot to get the glossy finish to blend.
2) Purchase your own polishing pads and grinder set up to polish them yourself. There are dry pads and wet pads. I’ve always had better results with wet pads, but they are kind of obnoxious to use indoors as it sprays a lot of water.
3) Use an enhancing sealer and/or topical film sealer on the etched spot. The sealer will fill in a fair amount of the rough surface, restoring the way light reflects off a smooth surface instead of refracting off a rough surface. You will bring back much richness to the tile. But make no mistake, the etching damage remains. It’s hard to predict how good or bad it would look using this cheap “fix”/band aid.
4) Is this tile squares, or is this a bid ol’ Slab? The last option is cheap and will restore the tile back to new if these are tile squares. But it’s a little intimidating. It’s to simply remove and replace the tile. Finding a tile (hopefully there’s one hiding in the basement or garage) is usually the tough part. But removing a tile isn’t too tough. We can talk you through each of the steps if you’re interested.
Old 07-11-2018, 06:44 PM   #4
Da Home Builder
Welcome, Ganch.
I can tell you how to fix the cat, but then I'd get hate mail, so I won't.
Old 07-11-2018, 07:18 PM   #5
Something tells me he was gonna suggest a catapult.
Old 07-12-2018, 06:22 PM   #6
ganch
thanks
many thanks for your advice - I don't have any of the tile anywhere, and I'm not terribly handy. so I think I'll go with the pro option. appreciate you taking the time. cat threw up on the rug yesterday, much easier to deal with.
Ganch
Black Marble Restoration PGT Cleaning, Restoration and Sealing 2 02-12-2016 06:46 AM
Black Marble...Epoxy or no? MarkTarkus Professionals' Hangout 16 01-28-2010 09:39 PM
Threw in the towel tools for sale Chicago area glen Professionals' Hangout 0 10-09-2007 05:14 PM
I just threw it up by what seemed right hamlet_jones Tile Forum/Advice Board 2 07-05-2005 01:12 PM
Black Roudy Marble Celin Tile Forum/Advice Board 6 10-31-2003 03:53 PM
