Old 10-10-2018, 08:49 PM   #1
riggyk
Aspiring Contractor - First Attempt at Tile Shower: Think Tank
Hey Everyone,
Been working supporting some old school contractors for many of my younger years, and now branching off onto some projects of my own, mainly a family home that needs renovation to start. I'd like to tackle a few walk-in tile showers, nothing too exotic or elaborate, but head-to-toe remodel. I've worked on a few similar jobs so I have some hands on experience and now feel confident to head out on my own, with some practice and planning. I've been watching youtube videos, Schluter-Kerdi instructional videos, and anything Sal Diblasi like a mad-man. I plan to do a deck mud pan and kerdi board with kerdi band and a kerdi drain.
Plumbing aside, I have a few questions for all you seasoned vets out there. Apologies if this has been covered somewhere before, but I thought it wise to check in here:
1) Where do faulty showers fail predominately? What is most important to keep in mind for avoiding common pitfalls?
2) What important micro-considerations/hacks are there from all you pros after many years on the job? IE: What are those small (or big!) 80/20 things you obsess over or give some extra anal consideration when doing a shower install that go a long way in guaranteeing a good result and minimizing your fear of a callback?
3) What resources would you recommend for further education before diving in? Are the Kerdi shower and bathroom remodeling (1 & 2) John Bridge e-books a must-read? Not trying to avoid the proper education here, I will gladly buy any and all reading and geek away, but just curious as to opinions.
4) I posted another thread about my practice deck mud pan, so if you care to weigh in, I threw that into it's own post.
Thanks in advance everyone! This forum is great!
Ryan
riggyk is offline   Reply With Quote
Old 10-10-2018, 08:58 PM   #2
riggyk
Practice Deck Mud Pan - Seeking Advice
Hey Everyone,
As seen in a similar post, I'm in the process of tackling my first walk-in tile shower, and am going to make a simulated deck-mud pan practice box from some 2X4 scrap in similar to identical surface area of my shower pan. I'd like to be very thorough and learn this head-to-toe so I want to practice perfectly if you know what I mean! My questions to all the pros out there, if you'd be so kind are:
1) Should I do this with actual deck mud? or would sand suffice? I assume actual deck mud to get the proper simulation.
2) Walk me through what I need to be cognoscente of while forming the pan, from a pros mindset. Aside from dimensions, are there any tidbits worth nothing for mixing, curing, packing? What are common issues to avoid? My thoughts are to screed a nice even surface with multiple trowels etc and check with a flash light to make sure there are no surface inconsistencies, sloping right to flush with the drain (below the extension), leaving room for tile above the deck and beneath the
3) 2.75" line on the perimeter, sloping down to 2" at the drain extension. Is this correct? What is a good way to guarantee the right pitch, by using a level? I've seen those leveling pitch sticks and heard mixed reviews on those.
4) Would Kerdi board (or any substrate for that matter) run to the sub floor behind the deck-mud pan, or does the substrate run down to the height of the pan, butting up on top of it?
I plan on doing this bad boy about 3-4 times to get a good feel for it. I appreciate all the wisdom you folks have to offer. Thanks so much!
Ryan
Old 10-10-2018, 09:30 PM   #3
1. I'd do it with real deck mud. It's pretty cheap, but a bit harder get rid of.
2. If you've drawn a level line all around the perimeter that has the desired height to provide the 1/4"/foot to the drain, it's fairly simplistic. FIrst, pack a band of mud around the perimeter at the needed height. You can use a level and a mallet to pack it down tight at the desired height while maintaining it being level as well. Then, use that and the rim of your flange as your guide...you can use a screed to shape the pan from the perimeter to the drain with it. You will probably need multiple straight boards to do the screeding to account for the variations in length between the edges and the drain on the rectangular surface.
3. Measure the furthest distance from the drain to the corner...make your line level around the perimeter at that level. Depending on the actual height of your drain add enough to get your at least 1/4"/foot (which is the minimum, it can be higher up to a point). Industry standards say a minimum depth of 1-1/4", but you can go thicker over a wooden subfloor. Isn't really needed, 2" is more than required at least for the preslope. The finished floor would be higher unless you're using a bonded sheet membrane, where there's only one slope.
4. It depends on the type of waterproofing you're doing. IF using Kerdi or a similar sheet membrane, yes, the board can go to the floor. If you're going with a traditional liner, no. Once the liner is in, then you run the walls down to it (with a gap) IF it's one that can be embedded. If you use something like HardieBacker, it CANNOT be embedded, so would be added after the final mudbed is installed. That also makes it harder to anchor since you can't put fasteners lower than 2" above the curb.
Old 10-10-2018, 11:02 PM   #4
Welcome to the forum, Ryan.
1. Usually around the curb.
2. Don't try to cut corners. Use a surface-applied membrane, installed properly, to keep the shower waterproof. There's usually no "fixing" a bad shower, most of them require a complete tearout and redo. So do it right the first time.
3. Other than this site, John's books are very helpful. Well worth the read.
Old 10-10-2018, 11:13 PM   #5
1- 90% of showers fail at the curb due to improper waterproofing
3- Manufacturer training, reps, and their YouTube videos. The only non-manufacturer tile guy on youtube to watch is Sal DiBlasi.
start here
Tile guy punctured my geberit in-wall tank fredericka3 Tile Forum/Advice Board 6 06-22-2018 03:16 PM
Noobs first shower attempt. mullet Tile Forum/Advice Board 40 03-02-2014 08:48 AM
First shower tiling attempt.. Lisn2me Tile Forum/Advice Board 14 10-05-2010 12:00 PM
First attempt at a mud shower Tempting_Fate Tile Forum/Advice Board 6 02-05-2008 04:15 PM
small Shower/bathroom redo...should I even attempt? acid Tile Forum/Advice Board 5 07-05-2007 11:00 PM
