Old 10-03-2018, 03:11 PM   #1
jb10
walk-in shower stall question
How far should I extend the tile on the left wall for this shower stall?
I want to stop the tile right where the shower pan ends into the drain (4.5 ft). Is that length OK without a shower curtain or door?
What would you do?
Jim
jb10 is offline   Reply With Quote
Old 10-03-2018, 06:35 PM   #2
Hi Jim, welcome. Without a door or curtain, I'm afraid you'll have some splashing on the bath floor with a shower that's 4 1/2 ft wide. Probably not a flood of water but some splashing. You could always try it and add the glass later if it's needed.
Old 10-03-2018, 06:52 PM   #3
jb10
Yes, the floor will be tiled all the way through past the drain to the other side of the room. So that's OK.
Jim
Old 10-03-2018, 06:54 PM   #4
Welcome, Jim.
I trust that would mean you intend to waterproof the entire floor and the walls at least a couple feet outside what you'll consider the shower area, yes?
I'm still not clear about your drain location.
Old 10-03-2018, 07:13 PM   #5
jb10
That's right. Ditra over the entire floor.
In the image you can see the centered cutout for a linear drain.
Kerdi goes all the way to the window--it's a question of how far I should tile it.
Jim
Old 10-03-2018, 08:30 PM   #6
workhurts
How much wall is to the left of the window and what kind of tile?
Ali
Old 10-03-2018, 08:38 PM   #7
jb10
There's a foot to the left of the window, using 12 x 24 porcelain
4.5' in the stall
2' to the window
2.5' window
1' to the left the window
Jim
Old 10-03-2018, 09:20 PM   #8
workhurts
Would tiling that whole wall look stupid?
Ali
Old 10-04-2018, 10:44 AM   #9
jb10
Could be done, but I'm trying to find out if I can get away with just tiling 4.5. That would be neat.
Jim
Old 10-06-2018, 10:46 AM   #10
Jim, that 4.5’ is fairly short for a door-less stall.
I think most folks that are reading this don’t have a full picture of what’s going on and I think that’s contributing to a smaller number of responses to you.
I’d want to know the rest of the details. We see what you’re talking about on the left wall and the physical location of the lineal drain. But...
If you want to stop the tile on the left wall at 4.5’, what are you covering the waterproofing membrane with?
How big are tiles inside and outside the shower pan?
How much is the floor sloped inside the pan and outside the lineal drain?
Using a level to determine this: what is the height difference between the top of the drain grate and the unsloped/flat/level part of the bathroom floor?
Are you overlapping the Kerdi inside the shower 2” onto the Ditra outside, or just abutting?
How big is the wall on the right, what’s it’s configuration, how far is it’s waterproofing, and how far is it being tiled?
Is there just one single shower head,which direction does it spray, and is a “normal” or high volume spray?
At least those are the first few questions that would help us steer you right.
Old 12-10-2018, 08:30 PM   #11
jb10
Thank you for your reply Tool Guy.
After posting this thread/question I've decided to tile the entire wall with 12 x 24.
As for the rest,
The floor has 2 x 2 mesh extending out of the shower to the opposite wall.
The floor is sloped with a Kerdi Tray.
Wall on the right has the shower valve.
The shower head is normal spray. You can see where in the new pics.
You ask a pertinent question about the level of the line drain relative to the floor. Mine calculations were a little off.
What's the best method to raise the level of the Kerdi Tray?
Jim
Old 12-10-2018, 11:08 PM   #12
Is the tray bonded to the floor yet?
How much higher do you want it to be?
Old 12-11-2018, 12:38 AM   #13
workhurts
You can adjust the trim a little too.
Ali
Old 12-11-2018, 12:41 AM   #14
Also, have you got the plywood flush with the joists? If so, you'll want to put a layer of plywood over it anyway, which was what I was going to suggest to address the height question, depending on how much you want to raise the floor.
Old 12-11-2018, 08:20 AM   #15
jb10
Most plywood is 1/4 and up and that's too thick. Any alternatives?
Notice that the Kerdi drawing does not account for installs that have ditra on the other side of the shower tray.
Jim
Walk in shower question for pre slope and pan Obeselee Tile Forum/Advice Board 8 09-17-2018 06:33 PM
pre fab shower stall question lati_cz Professionals' Hangout 6 04-06-2017 03:19 PM
Walk in shower question bayendeavors Tile Forum/Advice Board 0 09-01-2011 09:51 PM
Question about no curb walk in shower NorthernConfederate Tile Forum/Advice Board 4 04-05-2006 10:50 AM
walk in shower question: chukar8 Professionals' Hangout 6 08-10-2005 09:11 PM
