Old 10-03-2018, 08:10 PM   #16
Sounds like you may need a combination of the techniques...cbu to provide the height for the mudcap's leg, and the combing out thinset to raise the field tiles. Raising all of the field tile in the same step with a LFT mortar could be done, but it's a lot harder to accomplish with a nice flat end result.
Do the colors match? Even from tile from the same place and time, if they're in different batches, the colors can vary (usually slightly).
Old 10-03-2018, 10:16 PM   #17
Raymond S
Carpenter - Tile Setter
It would be a lot simpler to get some mudcaps from dal-tile that go with your field tile.
Using the thicker mudcaps will work, but it will require quite a bit of finagling and it may not be worth it you would need to stop the cbu and kerdi at the edge of the field tiles and either use a tiny strip of cbu behind the mudcaps ( difficult) or build up behind them with a mortar that can go that thick (tricky and messy).
Raymond
Raymond S is offline   Reply With Quote
Old 10-04-2018, 08:09 AM   #18
BrittanyATX
What if I have the bathroom built the old way, mud floated, wth hydroban or redguard applied over the surface of the mud instead of doing kerdi? This style is the bathroom design I'm going for with mudcap trimming all walls and covering tub/shower arch opening on both sides. would the difference in tile thickness be doable in that application?
@jadnashua, yes all the trim matches in color shade.
@Raymond It was $400 less for the old trim compared to purchasing modern daltile bullnose, I'm hoping I don't end up losing the savings in cost of prep.
Brittany
BrittanyATX is offline   Reply With Quote
Old 10-04-2018, 06:33 PM   #19
I don't see mud walls changing anything. Depending on what tile saw you have, you probably could make a jig to thin the BN down to 1/4.
I like Raymond's idea of getting new BN.
Old 10-04-2018, 08:28 PM   #20
BrittanyATX
@Davy: your jig idea is brilliant. That's what I'll do. I haven't gotten a tile saw yet, any recommendations on ones that I could do the jig idea with?
Brittany
Marble thickness-is a 5\16" thick 2" Carrara Hex over concrete subfloor thick enough? Babydoll66 Tile Forum/Advice Board 18 08-13-2015 04:43 PM
Need advice on fabricating "perfect" 45 degree bevel edge on 1/2" thick black galaxy Exsequor Professionals' Hangout 12 07-03-2014 06:34 AM
1/2" thick glass field tile Houston Remodeler Professionals' Hangout 8 08-18-2010 05:52 PM
3/8" Thick 4.25" Ceramic Tile kevin_111 Tile Forum/Advice Board 1 10-22-2005 08:06 PM
3/16" thick vs. 1/4" thick Ceramic Tile wessieball Tile Forum/Advice Board 3 02-26-2005 09:09 PM
