Old 09-15-2018, 09:19 PM   #1
mrmumbels
Corner drains
Anyone have any experience with corner shower drains. Iím not seeing a whole lot out there. The one below seems to pop up a lot but I donít see any reviews on it. Can anyone recommend one?
https://www.signaturehardware.com/th...yABEgIXFfD_BwE
jeremy
mrmumbels is offline   Reply With Quote
Old 09-15-2018, 11:02 PM   #2
No, havenít seen that before. But I did look at their ďinstructionsĒ. This drain is meant to be used in place of the top screw-in drain portion from a three-piece clamping drain. The instructions appear to have been written by someone who is not technically proficient in shower construction. They are not complete. And thereís some contradictory info.
But I did see links to all sorts of other drain designs.. Some had reviews on them. Either the reviews reflected poorly in the product...or there were glowing concise reviews...as though they were written by a marketing company.
Old 09-16-2018, 05:45 AM   #3
tilemanct
Tile & Stone
...and fun cutting in that first bottom row of tile all the way around.
CTEF Certified Installer
tilemanct is online now   Reply With Quote
Old 09-16-2018, 07:08 AM   #4
Joe-Tile
One of the options you can select is to add a drain flange and uncoupling. I've emailed them to see just exactly what that means. I'll report back once i hear anything. Seems like a cool drain to offer if the uncoupling flange means what i think it means.
Joe
3rd generation Owner of Joe Tile
Quality tile installation since 1948.
Joe-Tile is offline   Reply With Quote
Old 09-16-2018, 07:10 AM   #5
mrmumbels
Definitely cool looking and makes the bed an easy single slope down to it.
jeremy
Old 09-16-2018, 07:12 AM   #6
mrmumbels
Iím not worried about the cuts but now wondering if itíll look bad with that angle. Do you think the bed should have 3 angles down or a single from the opposite end? Iím not sure if Iím clear with that explanation.
jeremy
Old 09-16-2018, 07:24 PM   #7
Joe-Tile
I got a response and it was just your standard issue clamping ring drain, for 30 dollars extra.
I guess they got to make money to.
Joe
Old 09-17-2018, 08:43 AM   #8
Looks to me like an idea whose time has not come.
A slope to a line drain is fine, but to a corner? Nah.
Old 09-17-2018, 08:45 AM   #9
mrmumbels
Why nah?
jeremy
Old 09-17-2018, 08:51 AM   #10
As stated by someone earlier, the cuts at the walls would be murder on the eye in my estimation. But then again, I'm over the hill.
Old 09-17-2018, 09:30 AM   #11
wwhitney
Last time this came up, I was wondering if the slope along the walls leading to the corner drain needed to be the full 1/4" per foot. That would mean for a single plane floor, the slope on the diagonal would have to be about 3/8" per foot (sqrt(2) times as great).
Cheers, Wayne
Wayne
Old 09-17-2018, 07:44 PM   #12
mrmumbels
What were you thinking the uncoupling flange meant?
jeremy
Old 09-17-2018, 07:49 PM   #13
mrmumbels
I donít think itíll be too bad with larger tile. Iím seeing a lot of linear drains with a single slope.
jeremy
Old 09-17-2018, 08:12 PM   #14
Joe-Tile
I was hoping it was referring to uncoupling as in kerdi fleece material like on the kerdi drains. Not a clamping ring drain you can get for 10 bucks at the local box store.
Joe
Old 09-17-2018, 08:16 PM   #15
mrmumbels
Gotcha, if anyone has any ideas on the best way to make this work, my ears are open. Name:  IMG_2016.jpg
jeremy
Creating corner on island with quartz and no corner or bull nose pieces Chicagorealestate Tile Forum/Advice Board 4 10-25-2013 05:27 PM
corner bead for drywall/cement board corner FJK Tile Forum/Advice Board 11 07-10-2011 01:33 PM
pan liner drains dog Professionals' Hangout 6 09-21-2008 04:25 AM
Purus drains John R Tile Forum/Advice Board 1 04-22-2008 05:04 PM
shower drains aggiedad Tile Forum/Advice Board 2 02-09-2007 08:19 PM
