Old 10-07-2018, 06:51 PM   #16
diy-faq
Passed, water line didn't drop at all. Test pan didn't loose a drop at all either. Time to tile...not tonight, tonight is scotch!
Glen
diy-faq is offline   Reply With Quote
Old 10-07-2018, 09:55 PM   #18
diy-faq
Lagavulin
Glen
Old 10-19-2018, 06:58 AM   #20
diy-faq
Just picked up my marble top for the curb. When I installed the Kerdi curb I used 1/8" spacers to tilt it toward the drain, wondering if 1/8" is enough or should I tilt the marble another 1/16"? Or am I over thinking it?
Glen
Old 10-19-2018, 07:39 AM   #21
Gozo
The curb’s, what, maybe 4 or 5” wide? The 1/8” would give you a bit more than the desired 1/4” per ft slope. If using a glass door, adding too much slope could make any brackets for the glass, especially if it’s a slider, a bit problematic. Surface tension will still hold some water on the curb; the goal is to get it to run back to the shower pan, not the floor outside.
I think you’re over thinking it.
Jeff
Old 11-05-2018, 09:18 PM   #22
diy-faq
I had one tile loosly leaning against the wall, its a cut tile that is above the sloped bench and its giving me fits so i put it off until i get further along in the job. Well when i moved the tile the wall behjnd it was soaked, the back of the tile was completrely dry. It is an outside wall and it is well insulated. On that wall there are probably 25 tiles already installed, they are cold to the touch but no moisture appearing anywhere around them. Am i looking at a cold glass of water on a hot day situation, where the kerdi wall is cold and the room's heat warmed the tile causing condensation on the wall? There is no water sourse near that area so its not a leaky pipe.
Glen
Old 11-05-2018, 10:20 PM   #23
CaliGrown
CaliGrown's Avatar
Seems to be, been working outside lately and often find condensation under stacked tiles in the morning
El niño, Chris
Working to make a living... or something close to it.
Old 12-22-2018, 05:17 PM   #24
diy-faq
Shower door
Go to showroom pick out what we want, explain no drilling curb and lady at the desk says ok we can epoxy, guys come out to measure and I reiterate no drilling the curb and they say "huh", but ok. Get the contract and there is no mention of no drilling the curb. Write back saying no drilling the curb needs to be on the contract and they refuse to include it...back to the search. I'm not being outrageous am I?
Glen
Old 12-22-2018, 05:29 PM   #25
makethatkerdistick
Glen, been there myself. How complicated is your enclosure? Post a picture! It's not too difficult to pick the proper hardware from CR Laurence, submit your drawings to a glass company and do a self install. You won't save tons (but a little bit), will invest quite a bit of time but you will get what you want! I've done it twice (one neo angle and one simple shower door) and can give you some DIY tips if you want. It's a fun challenge.
The easier route would be to find a glass installer that will not drill the curb and will say so in their contract. Problem is that whenever you request a certain language to be included, they get suspicious and sense that you're a difficult customer. Happened to me, and they just ceased communication with me. They just move to te next customer whose curb they can drill without protest.
Wolfgang
Old 01-05-2019, 11:44 PM   #26
diy-faq
Set with the shower door...no curb drilling...3+ week wait...I'll wait 3 months at this point!!!
Now I'm onto the bathroom floor. First prelim floor layout yields full tile at bed/bath doorway and 6" tile at the shower (the other end of the the room). 12x24 tiles and the 6" will be cut from the 12", so it'll be a 6"x24" tile...ok or should I even it out to have 9" at the doorway and 9" at the shower. My gut says 6" out of a 12" tile is a good enough size. Thanks.
Glen
Planning master bath redo karla23 Tile Forum/Advice Board 11 11-18-2013 01:25 PM
Master bath redo excavator Tile Forum/Advice Board 16 05-08-2013 09:00 PM
Marc's Master Bath Redo presidentsdad Tile Forum/Advice Board 143 04-17-2012 01:51 PM
DJ's Master Bath Redo golf4dj Tile Forum/Advice Board 20 03-20-2012 04:23 AM
Master Bath Redo unregistered Tile Forum/Advice Board 31 02-26-2005 10:23 PM
