Old 09-19-2018, 02:26 AM   #61
I wouldn't use plumbers putty, I use a bead of 100% silicone. You're trying to form a gasket under the liner.
Old 09-20-2018, 12:01 AM   #62
mlawler626
Finally got the liner done. Ready to water leak test tomorrow.
Michael
mlawler626 is offline   Reply With Quote
Old 09-20-2018, 04:35 AM   #63
I've noticed Home Depot has their pan liners pre-cut and rolled up real tight. Sure makes it difficult to get the wrinkles out. I laid the last one out in the front yard for a while and it still had wrinkles.
Old 09-20-2018, 10:58 AM   #64
mlawler626
@Davy, I ordered a 6 x 8 ft liner from internet. It came folded over, rolled up tight, and vacuum sealed in plastic wrapping in a 4ft long box. I did not lay it out in the sun... ( I didn't know to do this...). I did the best I could to smooth it out.
Now taking advice from someone else (and ignoring the goof-proof video instructions)... I cut the center hole out before putting on the drain clamping flange... to make sure the weep holes are not blocked (Goof-Proof video shows cutting hole out after the clamping flange is on... and after leak test... but my friend stated the liner might seal up against the inner body of clamp piece-- thus blocking the drain weep holes).
So now I need to figure out how to temporarily block the drain weep holes to do my leak test.
Michael
Old 09-20-2018, 04:36 PM   #65
rmckee84
rmckee84's Avatar
You'll need an inflatable test ball that can be placed below the weep holes to plug the drain.
Ryan McKee
Old 09-20-2018, 05:56 PM   #66
Michael, after you get the pan folded and nailed across the top, you then have to cut the liner over the center hole in the drain. You then can slightly lift the liner at the cut out and shoot a bead of silicone in a circle between the top of the bottom flange and the underside of the liner. Then a small X cut can be made over each bolt head and then the liner can be forced over the bolt heads. Then you can bolt down the round flange. I'd let the silicone dry and then flood test it. Like Ryan said, you'll need to buy a test ball that goes down into the riser pipe that's below the drain. Some folks have used a balloon, pushing it down the drain enough to plug it. Then just pop the balloon when you're done and it'll go on down the drain. But, any way you test it needs to be low enough in the drain to test that silicone gasket.
Old 09-21-2018, 06:04 PM   #67
mlawler626
@Davy, after I got the the two corners folded and nailed and one down each side from the corners... I rolled back the liner and put a bead of 100% Silicone around the flange...
...then I made a small X over each of the screws and pushed the liner over them... then I cut out the center hole. The weep holes are all clear.
I got the CBU installed today. Spaced it 1/2" off the liner around the bottom.
Michael
Last edited by Tool Guy - Kg; 09-29-2018 at 09:50 PM. Reason: Rotate Picture upright. :)
Old 09-21-2018, 06:20 PM   #68
mlawler626
very aggravating that it's rotating the picture
Yes, I know the shower pipe is inverted-- it's the old one and just in there temporarily.
Michael
Old 09-23-2018, 07:37 PM   #69
mlawler626
I got the CBU taped with Cement Board FibaTape... then used an unmodified thinset.
Michael
Last edited by Tool Guy - Kg; 09-29-2018 at 09:51 PM. Reason: Rotate picture upright. :)
Old 09-24-2018, 08:13 PM   #70
mlawler626
Got the first (horizontal) coat of PROFLEX HYDRA-SEAL applied (I taped off the ceiling). Goes on Navy Blue... dries a very dark blue. 2nd (Vertical) coat up next...
Michael
Last edited by Tool Guy - Kg; 09-29-2018 at 09:52 PM. Reason: Rotate picture upright. :)
Old 09-29-2018, 07:58 PM   #71
mlawler626
I got the Quick-Pitch sticks installed... Kirb-Perfect is next...
Michael
Old 10-02-2018, 12:48 PM   #72
mlawler626
Question: Is Mapei 4 to 1 Mud Bed Mix (Sand and Cement Mortar Mix) good to use for the Shower mud bed over the Quick-Pitch?
Michael
Old 10-02-2018, 01:27 PM   #73
Yes, that will work.
Old 10-02-2018, 02:46 PM   #74
mlawler626
Thanks Kevin, also in watching another video on mud bed mixing, etc. I heard the guy say to install cement board screws 8" apart-- I did not do this... I just eyeballed 1 foot spacing. Should I be concerned??? Go back and add more screws?
Michael
Old 10-02-2018, 07:48 PM   #75
Can you feel the wall flex?
More won't hurt as long as you can waterproof over the new screws.
corner from shower alcove to drywall hbryan Tile Forum/Advice Board 5 04-14-2014 01:19 PM
Transitions from tiled room to other floor DIY-Renovator Tile Forum/Advice Board 24 07-21-2008 03:49 PM
Re-doing tiled shower stall, damaged drywall?? RochesterGT Tile Forum/Advice Board 10 01-23-2007 07:49 PM
Re-doing tiled shower stall, damaged drywall?? RochesterGT Cleaning, Restoration and Sealing 1 01-02-2007 05:40 PM
My shower was tiled on drywall!!!! MM Tile Forum/Advice Board 1 11-22-2004 07:40 AM
