Old 10-04-2018, 03:50 PM   #46
Rigo
Rigo
Im ripping out the tile I will be replacing and so far so good. Thank god they used unmodified under the backer board. I did notice they used nails and drywall screws. The nails were a bit rusted, but the screws were solid. I should just use those screws instead of the rock on screws, Im kidding. By the threshold they didn't even screw that part down and it was still solid. Anyways I have a couple of uneven spots where the plywood sheets come together. Im gonna smooth them out with my cup wheel. When I finish, there might be a couple of low spots, can I just fill them in with thinset before I install my durock?
Rigo
Rigo is offline   Reply With Quote
Old 10-04-2018, 04:31 PM   #47
CBU instructions say either hot-dipped (not electroplated), galvanized roofing nails or corrosion resistant backer board screws to anchor the stuff.
You can see they didn't set the tile very well as the coverage is poor underneath both the tile and the cbu.
Old 10-04-2018, 05:24 PM   #48
Rigo
Rigo
Yes sir Jim I agree with ya. I bought a big box of Rock On screws for my project.
Rigo
Old 10-04-2018, 11:02 PM   #49
You asked earlier if your tile was flat enough to do a 50% stagger...place two of the tile finished side to finished side and see if they rock or there's a gap in the middle. If they make intimate contact, you should be good for any layout. If not, go by the industry guidelines and the manufacturer's instructions. To be safe, you might want to do that with some random tile from multiple boxes just in case. WHile it's rare that they're absolutely flat, it does happen with some, giving you more options.
Old 10-05-2018, 03:17 AM   #50
Rigo
Rigo
Thanks for the tips Jim. They do seem really flat and no rocking, Im gonna shoot for a 1/3 and 1/2 mix pattern. Im still hung up on my transition from tile to wood laminate, I got a bunch of ideas so hopefully it all falls into place. Then my tub is curved a bit, so Im reading the forum for ideas on how to cut my tile for that too.
Rigo
Old 10-05-2018, 03:09 PM   #51
rmckee84
rmckee84's Avatar
I make a template with cardboard then trace it onto your tile.
Ryan McKee
Old 10-06-2018, 12:17 AM   #52
Rigo
Rigo
Thx Ryan, I will do that.
Rigo
Old 10-09-2018, 12:30 PM   #53
Rigo
Rigo
Im marking where my cement boards are gonna go and trying to do it so I have less cuts. Is it the end of the world if one section is 12 inches instead of Durock 16 inch min at one of the joints?
Rigo
Old 10-11-2018, 07:54 PM   #54
Rigo
Rigo
Man I suck, took me all day to dry fit these boards. Also, HD didn't have a dust shroud, so I took the cup wheel to the plywood. My wife was so pist with all the dust haha. I used a Dremel to cut my boards, was really fast. Does my progress look okay so far?
Rigo
Old 10-12-2018, 07:28 PM   #55
rmckee84
rmckee84's Avatar
Everybody works at a different pace...I despise CBU it's heavy, dusty, and time consuming. Thats why i made the switch to uncoupling membrane years ago.
Ryan McKee
Old 10-12-2018, 08:33 PM   #56
Rigo
Rigo
Yeah my back is killing me going up and down the stairs with everything. Went well today. I used un-modified under the durock and then I used modified for the cement board mesh tape. Gonna tile tomorrow hopefully.
Rigo
Old 10-22-2018, 01:01 PM   #57
Rigo
Rigo
Im almost done with my project, just have two more rows to put down. I searched and searched but didn't really find an answer. I found a reducer that matches my laminate, but it doesn't really fit. I took a table saw to it and it looks like it is gonna work. The reducer is laminate and I am gonna scuff up the edge a lil bit. How can I repair the edge if I don't have such a clean cut? The bottom pic is my mock up, of what Im working with.
Rigo
Old 10-22-2018, 04:37 PM   #58
I can't see your "scuffed up" cut, Rigo, but it's likely you can touch it up a bit with some wood stain and maybe a bit of polyurethane if needed. Doesn't sound like it's gonna be a big eyesore. If you're such a person who shines his shoes, brown shoe polish was once a go-to for such minor scratches, kinda like fingernail polish for tiny tile chips. Although with nail polish a fella usta have about a brazillian color choices.
Old 10-22-2018, 04:51 PM   #59
Lou_MA
Reminds me of an old joke:
Secretary of Defense is giving the president his daily briefing. He concludes by saying: "Yesterday, 3 Brazilian soldiers were killed."
"OH NO!" the President exclaims. "That's terrible!"
His staff sits stunned at this display of emotion, nervously watching as the President sits, head in hands.
Finally, the President looks up and asks, "How many is a brazillion?"
Lou
Old 10-22-2018, 05:45 PM   #60
Rigo
Rigo
Thx CX, the scuffs are really small. I will follow your advice.
Rigo
First tile project. How to make level transition to laminate. TTHonay Tile Forum/Advice Board 1 04-04-2016 03:25 AM
Tile and Laminate Floor Transition OyiwaaNoela Tile Forum/Advice Board 6 07-04-2014 04:01 PM
transition tile to Pergo laminate Emil Volk Tile Forum/Advice Board 7 04-28-2009 06:41 PM
Transition from Tile to Wood Laminate daley Tile Forum/Advice Board 3 06-13-2006 03:15 PM
Transition between tile and laminate (and other newbie questions)? mknight Tile Forum/Advice Board 11 09-27-2003 11:57 AM
