Old 05-16-2017, 11:13 PM   #16
2stubburn1
Ok....here is THE Quote I was waiting on ......please weigh in. Thanks
Recommended by tile shop.. commercial and residential, lots experience with epoxy and quartzlock. Licensed and insured. Please let me know what you think. Thanks!
Chrissy
2stubburn1 is offline   Reply With Quote
Old 05-18-2017, 04:41 PM   #17
2stubburn1
Please help me vet this installer/quote. Thanks!
Recommended by my local high end tile shop. Does commercial and residential work. Experienced with epoxy grout. Licensed, bonded, insured. Said he has had the same team who work jobs with him for many years.
Felt the price was a bit high, but it seems the only thing I have to buy is the tile, which I believe I can use his discount for. Was thinking it was weird he didn't itemize though. His verbal quote before seeing my actual bathroom as I described my budget and project was $2100. then when he came out he remarked that this would be a really straightforward job which leaves me wondering why the increase.
What do you think? Does this seem like a fair price from a quality installer or.......?
Chrissy
Old 05-18-2017, 04:59 PM   #18
Chrissy,
Where are you located? Please add this to your User CP linked in the dark blue bar above.
From my reading of the estimate, it looks like he is doing a quality job. I can't speak to the reasoning for the price increase. Looks to me like a good deal.
What I can say is the price seems quite low considering what I would charge. But then again I'm expensive.
Old 05-18-2017, 05:24 PM   #19
rmckee84
rmckee84's Avatar
Price seems fair. I don't itemize all my quotes either, the problems arise when a customer sees you complete a section that is itemized and wonder why it costs X amount of dollars and it only took me Y amount of time.
Ryan McKee
Old 05-18-2017, 08:36 PM   #20
Karls tile Inc
Tile and stone contractor Tile setter
Looks good to me as well. Maybe ask for a reference from a past customer of the installer.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Old 05-18-2017, 08:54 PM   #21
Arizona Floors
ReTile
Arizona Floors's Avatar
Quick correction, Paul. You are not expensive, you just know what your worth.
As to the quote, it's low for what I would charge.
Arizona Floors is offline   Reply With Quote
Old 06-16-2017, 09:15 AM   #22
2stubburn1
Conundrum during install....
Hi again everyone,
So i got my quote for install with herringbone pattern. Now my installer says he wants to do a right angle herringbone not a diagonal herringbone and that diagonal will cost extra. I am a bit miffed as I thought traditional herringbone WAS diagonal and didn't feel I had to specify that I wanted diagonal herringbone. There was no previous discussion on this until now. What do you guys think? My main concern is I have a very small and narrow bathroom and I thought the right angles would make it worse, hence why I wanted herringbone in the first place.
Chrissy
Old 06-16-2017, 09:36 AM   #23
Originally Posted by Chrissy
Now my installer says he wants to do a right angle herringbone not a diagonal herringbone...
I'd need a photo of what each of you is talking about to even enter that discussion, Chrissy.
Old 06-16-2017, 09:51 AM   #24
2stubburn1
Pics of diagonal vs right angle herringbone....
The first is diagonal herringbone (Google herringbone and this is what most pictures will show)
The second is right angle herringbone sometimes called straight herringbone.
The last is pic of my old bathroom. The floors were a lot worse then they looked in these pics.
Thanks.Attachment 195761
Attachment 195762
Attachment 195763
Attachment 195764
Chrissy
Old 06-16-2017, 12:07 PM   #25
OK, same pattern, different orientation. Both are herringbone.
He'll have a lot more cuts with your desired orientation and he may get confused in laying it out and he may well want to charge extra if his bid was for the "right angle" orientation. If it was not made clear and his bid was for herringbone and you wanted it in your diagonal orientation, y'all have a bit of a communication problem. I generally like those to end up in favor of the customer whenever possible, and this would be one such situation. He knows you didn't want what he wants to do, which is take the easy way out.
Old 06-16-2017, 08:58 PM   #26
jdtVA
Tile Fire
jdtVA's Avatar
Chrissy,
I'm in Northern VA and that seems like a low price. Just search for a "Certified Tile Installer" (CTI) they are your best bet for installing proper waterproofing and experienced with epoxy grout. You get what you pay for. I have been to many leaking shower pans that were put in less than 10 years ago by the lowest bidder. Good Luck!!
Justin
jdtVA is offline   Reply With Quote
Old 06-20-2017, 04:49 PM   #27
2stubburn1
Please weigh in on my floor. It has not been grouted yet.
What do you guys think? Is this a solid job? I am no expert. I want to know if we are on the right track before my tiler grouts as he is using epoxy. Thanks.
Chrissy
Old 06-20-2017, 05:05 PM   #28
evan1968
Not So Senior Contributor
evan1968's Avatar
What's with the small tile/ huge grout joint in the first and last pic?
Ooo...it's in the 3rd pic too! Found Waldo!
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
evan1968 is online now   Reply With Quote
Old 06-20-2017, 05:35 PM   #29
2stubburn1
What would you suggest I tell this guy?
He has already laid the thin set and it will dry by tomorrow morning. Is he going to need to rip the whole thing out and start over? He has one whole box left unopened. It's not like he ran out of tile. Plus, there is plenty of this tile in stock. I could always get more. I told him not to compensate by making the joints too wide and he laughed and said of course not it will all be 1/8 joint.
I feel sick. He is doing all this while we are at work. We used our vacation up last week prepping everything and can't be home to watch him.
Chrissy
Old 06-20-2017, 05:45 PM   #30
evan1968
evan1968's Avatar
To me it just looks funky. Maybe it's the pattern in the tile that's throwing me off or the angle of the pic. The grain of the "wood" seems like it's going in the opposite direction of the others.
Other than that one tile, that pattern looks like it came out ok.
Craig
Looking for insured & licensed pro epoxy tiler in Baltimore, md 2stubburn1 Professionals' Hangout 0 04-20-2017 07:30 PM
Busting Un-licensed tile contractors Swedes Tile The Mud Box 89 02-17-2015 10:41 AM
I need a licensed Tile Installer in Cook County, Illinois Go Irish Professionals' Hangout 2 10-02-2013 05:42 PM
Tiling Needed by Licensed Professional - Marin County, CA ss_marin Professionals' Hangout 6 09-06-2011 06:55 PM
Need licensed/insured Kerdi installer in Atlanta albionwiggina Professionals' Hangout 4 03-17-2011 08:07 AM
