09-17-2018, 09:29 PM
#16
I’ve decided to take a shot at a dawnusa.net triangle drain. It was on amazon so an easy return if it looks cheap or I find it can’t be done.
jeremy
09-18-2018, 03:56 AM
#17
Well the short version is your going to have to jack hammer the floor to relocate the drain.
The not fun version is your going to have to be spot on with your measurements in order to have it sitting perfectly into the corner. I would temporarily set a couple pieces of your backer board, and even dab some spots of thinset on the wall to set a couple tiles into the corner to get a better idea on placement. Can't have that thing set to far in or it'll be under the wall, and to far out will just flat look awful trying to fill the gap after.
Joe
3rd generation Owner of Joe Tile
Quality tile installation since 1948.
09-18-2018, 05:06 AM
#18
Jackhammering is done. I posted a pic above. The measurements and waterproofing scare me. I ordered the drain last night so I’ll see what happened. Once I have it in my hands it’s a lot easier to visualize.
jeremy
09-19-2018, 06:13 PM
#19
Cool, keep this thread posted I'm curious how it comes out and how tedious it is to do the drain rough in. Just curious when the things comes in could you post the outside diameter measurement of the giant rubber seal that goes into the drain flange please.
Joe
09-19-2018, 06:17 PM
#20
Corner drains
I actually went with a cheaper flange. The one they recommended was metal and had bad reviews due to price(I pictured it rusting in a few years). Reviews said it’s the exact same as any other cheaper flange. The one I ordered came in today and the outside diameter of the rubber gasket is 2 3/16. It fits in the threads prefect or I could screw in a normal drain cap.
jeremy
09-20-2018, 10:26 AM
#21
Drain came in. Looks to be really good quality and quite thick. 14guage to be exact.
jeremy
09-26-2018, 05:48 AM
#22
Realized one thing with this drain that I don’t like. The drain has no pitch in the stainless. So there’s always going to be some water left in the triangle. :/
jeremy
09-26-2018, 06:02 AM
#23
Thanks for the info. Can you set up a jig that supports all 3 corners nicely then use a piece of wood and hammer to bang down on the center and create a little pitch yourself?
Joe
09-26-2018, 07:07 AM
#24
That just might work to get a a few millimeters. The sides are all folded up with only welds on the .5" of every corner so I don't believe it would affect it there.
jeremy
10-08-2018, 08:03 AM
#25
Gap beetween hardi backer and mud bed
What do you guys fill this in with? I'm doing a corner drain shower so I have a good 3" gap towards the drain between the hardi and the deck mud.
I was thinking a thicker thinset would likely hold without slumping too much.
jeremy
10-08-2018, 08:38 AM
#26
There shouldn’t be a gap that big. I’d remove that piece of Hardibacker and replace with one that’s more precisely cut. How are you waterproofing the shower?
Lou
10-10-2018, 09:19 PM
#27
This is my 4th shower in my last 2 houses that have had those gaps. They always bring the drywall to the bottom plate and fill in the gap with something that I can’t figure out. This is the first time I’ve actually removed that material. Redguard for waterproofing.
jeremy
11-17-2018, 09:40 AM
#28
Drain is all good. Works great. I did end up making a triangle out of 2x4s and hammering down the center drain a tiny bit with a rubber mallet to create a pitch inside the drain. It’s a tiny bit off but hey I’m no pro.
jeremy
11-17-2018, 09:45 AM
#29
Wow, that bathroom looks spectacular!
11-21-2018, 08:01 AM
#30
jeremy
