Unread 10-04-2018, 03:13 PM   #16
Originally Posted by Monica
If you are okay with editing my title to Monica's Shower or something similar
Ok, there ya go. Not the title I would have chosen, but whatever floats your boat.
Unread 10-04-2018, 04:17 PM   #17
Larmonkm
I expect nothing less after a suggestion like mine. lol
Monica
Larmonkm is offline   Reply With Quote
Unread 10-05-2018, 05:11 AM   #18
Larmonkm
2 questions (Curb & Hardiebacker above shower pan)
Bc it's fiber cement, we installed it where it's not embedded.
I know that once the tile is installed, it will be sealed, not grouted, at the seam.
1. Do we need to do anything between where the hardiebacker ends and the shower pan begins? Such as silicone?
Or, do we tile as usual and seal the tiles along the seam only?
2. We used Aquadefense on the walls, but not the floor, as we have the liner below the bed. Is there anything special to do to the curb? My husband is terrified it's going to leak there. We did everything we read to do here. Preslope, liner (over curb and corner pieces added), water test, no punctures below 6 inches, no punctures on curb top or inside, etc.
Is it appropriate to use the Aquadefense over the curb? Or no bc of the liner?
Monica
Unread 10-05-2018, 06:17 AM   #19
I think in both cases there's nothing you need to do. The liner will work if installed properly.
David & Monica's Bathroom Remodel Monicakm Tile Forum/Advice Board 73 09-02-2015 06:05 AM
Has anyone used this grout dye, or something similar? Angelique Tile Forum/Advice Board 3 04-17-2014 03:29 PM
Similar Problem sslampkin Tile Forum/Advice Board 1 08-01-2013 11:37 AM
Monica's Master Bath Reno MonicaBenavidez Tile Forum/Advice Board 46 03-21-2012 03:27 PM
David & Monica's 100% Finished Master Bath Monicakm Tile Forum/Advice Board 16 02-12-2008 04:50 PM
