Unread 10-10-2011, 08:26 PM   #1
westislandguy
tiled Shed floor
Ok i know it sounds crazy and probably is, but yes i tiled the floor of my shed.
I had some left over ditra and had procelain tiles.
But anyways, spoke to schluter and they say no problem, i followed their guidlines:
My shed floor is 6'x8' and made of 2x6's every 16" with 3/4 plywood.
As per schluter recommendations i added 1/2 durock using modified thinset and screws.
Then i put down the ditra and used unmodified thinset as per schluter recommendation and set my tiles with again the unmodified thinset.
It looks good and i was pretty confident of myself but i've been reading that we should use only modified mortar for outdoors since it's more resisting to cracking.
What do you guys think, altought my tiles are not technically outdoors, they still will be affected by the extreme temperature changes here in Quebec.
Manny
westislandguy is offline   Reply With Quote
Unread 10-10-2011, 10:52 PM   #2
Modified mortars are more resistant to cracking? Well, that's not true all by itself. It's true that some modified mortars are more flexible. And if there's some differential movement between the substrate and tile, it may flex enough to keep a crack from being inflicted on a tile. But you've installed your tiles per Schluter specs over Ditra. If some differential movement occurs, the Ditra is there to relieve the stress between the two. You did good.
As long as the 2x6 joists are up to the L/360 deflection rating, you're good to go. Take a look at this Deflecto calculator to see how your floor structure rates.
Unread 10-11-2011, 07:40 AM   #3
westislandguy
I scored L/839 so i should be good.
Thanks for the link.
Manny
Random Rock & Mortar Shed Floor Bush Master The Mud Box 1 05-24-2011 09:13 PM
wall tiled, floor tiled, but what about baseboard? johnm sr Tile Forum/Advice Board 5 04-09-2010 09:55 AM
My shed thread. dbol The Mud Box 35 06-16-2008 02:53 PM
where tiled wall meets tiled shower floor ambaji Tile Forum/Advice Board 9 11-08-2004 08:33 PM
Shed some light, willya annieef Tile Forum/Advice Board 2 10-27-2003 11:35 AM
