Unread 03-12-2014, 04:25 PM   #1
Markg1
Markg1's Avatar
Mark's Half Bath
I'm starting another bathroom remodel. This one is a half bath. The room is 5' x 8' with just a toilet and a vanity. The old floor was the thin (3/8"?) Bruce oak. I ripped that up and found 1/2 particle board over 3/4 OSB (except for a 3/4" plywood patch under the toilet). Both the particle board and plywood around the toilet were soaked through and sagging. I cut a decent margin around there and put in a new piece of 3/4 OSB, getting out to get the tongue where I could. Glued and screwed it down and screwed down the rest so it is solid now. I plan on putting down Ditra then a mosaic. The issue is that we want the floor to be about 1/2" higher.
1. I know it doesn't add a lot of strength, but is there anything wrong with putting down another layer of 1/2" plywood or OSB?
2. Should it be glued or just screwed down?
3. I remember reading somewhere that the second layer should not be screwed to the joists, is that right?
Mark
Markg1 is offline   Reply With Quote
Unread 03-12-2014, 04:30 PM   #2
Richard Tunison
Retired Tile Contractor
If you need the extra height why not use 1/2in. cement board. Be aware that mosaics smaller than 2 in. are not to be used with Ditra.
Richard
Richard Tunison is offline   Reply With Quote
Unread 03-12-2014, 04:34 PM   #3
Markg1
Markg1's Avatar
The mosaic is white 2 X1" rectangles surrounding a blue 1x1" square pattern. I plan on filling the ditra with thinset to flatten it out prior to setting the tiles.
Mark
Unread 03-12-2014, 04:38 PM   #4
Mark, it matters not when you fill the Ditra waffles, the manufacturer still recommends against any tiles smaller than 2x2 inches in size.
An additional layer of half-inch subflooring, properly installed, would substantially stiffen your subfloor, especially the part cut up with patches. Use mechanical fasteners only and do not fasten into the joists.
Unread 03-12-2014, 04:43 PM   #5
Markg1
Markg1's Avatar
What would be best to put the tile on then? Cement board, plywood, OSB?
Mark
Unread 03-12-2014, 04:54 PM   #6
A CBU or sheet membrane over the added plywood would work.
Unread 03-12-2014, 08:32 PM   #7
Markg1
Markg1's Avatar
We only want another 1/2", so would 1/4 in plywood then 1/4 " CBU work?
Or would 1/2" CBU be better?
Mark
Unread 03-13-2014, 06:14 AM   #8
Markg1
Markg1's Avatar
bump
Mark
Unread 03-13-2014, 07:28 AM   #9
Richard Tunison
Like CX said, 1/2in. ply and a thin sheet membrane will be optimum.
Ditra and Nobel seal are about 1/8in. thick. Greenskin is about at thick as a dollar bill. Many others to choose from.
Richard
Unread 03-13-2014, 08:34 AM   #10
I think NobleSeal measures only about thirty mils in thickness, Richard.
Unread 03-13-2014, 09:22 AM   #11
Richard Tunison
You are right CX. I stand corrected and will store that tid bit away.
Richard
Unread 03-13-2014, 09:33 AM   #12
Markg1
Markg1's Avatar
OK, I hadn't heard of those, but they are kind of like Kerdi, no?
I had just bought a roll of Ditra for that bathroom. Guess I will save it for the kitchen or masterbath where we'll be using bigger tiles.
Mark
Unread 03-13-2014, 09:37 AM   #13
Richard Tunison
Oppps. I forgot about your small tiles when I mentioned Ditra.
Greenskin is peel and stick.
http://www.devcomtape.com/uploads/GS...data-sheet.pdf
Richard
Unread 03-13-2014, 10:32 AM   #14
Markg1
Markg1's Avatar
Not finding anywhere I can get my hands on greenskin or Noble Seal by this weekend. Could probably deal with the height of a 1/2" ply plus 1/4" CBU (will be trying to match that to the travertine in the kitchen when we get around to doing that).
Will the 1/4 CBU be good enough water proofing for around the toilet?
Do I need to seal it or is mesh tape and thinset good enough for the seams?
Mark
Unread 03-13-2014, 10:37 AM   #15
Richard Tunison
CBU is not waterproof,,,,,,it just provides a proper substrate for the tile.
Yes, imbed alkali resistant mesh into thinset on all of the seams. Leave a small gap at the perimeter of the room and put nothing there. This is for expansion.
Richard
Mark's Master Bath Remodel Mark Lammert Tile Forum/Advice Board 106 09-11-2009 08:50 AM
Half bath to full bath conversion project pmoe Tile Forum/Advice Board 30 06-10-2009 10:42 PM
Mark's Master Bath Reno HotinOKC Tile Forum/Advice Board 17 08-02-2008 04:13 PM
Mark's Bath Remodel m_westall Tile Forum/Advice Board 27 08-01-2006 10:31 PM
Mark's Bath Remodel m_westall Tile Forum/Advice Board 7 03-29-2006 02:59 PM
