Unread 05-21-2019, 12:09 PM   #1
chaindriven
Outside the alcove
I'm at the part in this bathroom reno where I've fixed all the framing and done all the rough, and am wondering what the best practice is for continuing tile, waterproofing, and backerboard past the edge of the tub.
Here's what I'm planning...In the photo, the joint between the new 2x6 on edge and old 2x4 is 32" from the corner. I'm thinking of running Durock to that joint, where drywall will take over. Will thinset and mesh tape that joint and then apply hydroban a couple inches past the joint. This will leave me with alternating courses of a full tile and two half-tiles, each with a 2" bullnose. The bullnose straddles the joint between the hydroban and untreated drywall (I'm painting, but well shy of the tile, and will fill that in later.)
BTW...If you notice the gap between the tub and wall, it has yet to be furred out. In process (see plywood at bottom plate). But wanted to resolve this first.
Am I doing anything wrong?
Thanks, Mark
PS been lurking a long time. This forum gets mad props for being a place where people can disagree without getting ugly. Who knew there was such a place on the internet??
Mark
In theory, there is no difference between theory and practice. But, in practice, there is.
chaindriven is offline   Reply With Quote
Unread 05-21-2019, 12:15 PM   #2
Welcome, Mark.
Forgive my density, but you don't appear to have "a couple inches" of wall past that joint. What am I missing?
Unread 05-21-2019, 12:21 PM   #3
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
In a perfect world, joints in drywall and tile backer wouldn't land on framing joints, but if that's unworkable, I'd just make that 2x6 and 2x4 as close to one-ness as possible with fasteners and maybe PL Premium. Mesh tape and bed as you describe should be adequate.
If you're furring the whole wall, why not rip a strip of ply to bridge across the 2x4 and 2x6?
Peter
Unread 05-21-2019, 01:50 PM   #4
chaindriven
Peter- You mean like this?
That was the plan all along, but I was wanting to get my question asked.
I should just have waited until I had it done.
Mark
Last edited by chaindriven; 05-21-2019 at 01:51 PM. Reason: left out reference to person
Unread 05-21-2019, 01:54 PM   #5
chaindriven
CX-
The Hydro Ban is brush applied to the cement backer and the drywall, just beyond the joint. Now, I'm afraid I'm the dense one. I posted an updated photo in a different reply...
Mark
Mark
Unread 05-21-2019, 02:24 PM   #6
Carbidetooth
Hmmmmm
I think CX was imagining a doorway to the right of tub there. I'm assuming that's a stud bay...correct?
Peter
Unread 05-21-2019, 02:26 PM   #7
chaindriven
Ahhhh. Now I get it. Correct. It's a stud bay.
Mark
Unread 05-21-2019, 02:59 PM   #8
Thanks, Peter. Yes, that's what I thought.
Unread 06-26-2019, 12:28 PM   #9
chaindriven
removing two 2x2 mosaics from newly laid floor
So, I don't know exactly how this happened (a lie: it was a few moments of inattention while setting, and then a few more while "reviewing").
Anyway, I have two tiles that stand proud of the rest of the floor (shown in harshest possible lighting). They stand about 1/16" proud of the rest of the floor on one edge. These were set yesterday. I'll take whatever time and care it takes to get these out and properly replace them, but I'm not sure what the best approach is: Inclined to drill a series of holes with a small diamond bit as deep as the tile is thick, and then use a bung chisel to break up the pieces. Other thoughts welcome...
I did a search, but most of the results were wall related.
Other info: 5/16" porcelain, Laticrete 253, 1/4" CBU over 1-1/4" plywood (two sheets), 3/16" X 1/4" v-notch trowel carefully held at a right angle.
Thanks for any advice.
Mark
Unread 06-26-2019, 01:00 PM   #10
Since they're over CBU, Mark, I'd just use a nail punch. Start at a corner of the high edge, work your way back.
Unread 06-26-2019, 01:22 PM   #11
chaindriven
How beautifully, primitively simple. Thanks :-)
Mark
Unread 06-27-2019, 05:57 AM   #12
Right?
That's how I removed a 12X24 tile on my floor that I screwed up. LOL
Alcove tub too short cloosbro Tile Forum/Advice Board 13 04-16-2012 11:14 AM
Using a drop-in tub in an alcove cheakamus Tile Forum/Advice Board 8 01-27-2012 08:18 PM
Please Help. Drop-in Tub in Alcove guru10cea Tile Forum/Advice Board 26 12-12-2011 01:26 AM
Tub alcove Lojac Tile Forum/Advice Board 18 10-24-2011 05:39 PM
Tub Alcove andrew390 Tile Forum/Advice Board 0 10-31-2006 08:52 PM
