Unread 05-21-2019, 07:47 AM   #46
A little Boric Acid will provide pretty good protection from termites when properly applied to common kiln-dried lumber.
Unread 05-24-2019, 11:53 PM   #47
Anthocar
I took y'all's advice and ditched the plastic curb. The continuous piece of lath seemed like the way to go by far. Thanks for the advice so far. Mud bed is going in tomorrow.
Sent from my SM-N960U using Tapatalk
AC
Anthocar is offline   Reply With Quote
Unread 05-26-2019, 03:20 PM   #48
Anthocar
Shower Valve Rough In Install
Sorry if this has been posted elsewhere but I couldn't find anything on this site and I want to verify before I start cutting holes in my backer board...
It's seems like I ams supposed to cut a hole in the shape of the square plaster guard (black square in picture) in my wall. The plaster guard then should sit flush with my finished wall (cbu + tile).
Is that right?
I've seen other install pics with a circle hole cut out to fit the shower valve cylinder only so I figured I'd ask the pros on here before I did any final cuts.
Thanks in advance for the help!
AC
Unread 05-26-2019, 03:40 PM   #49
ZZZK
Yes the plastic box should sit flush with your finished tile. Usually that means the box would stand proud 1/2" feom your backer board allowing 3/8" for tile and 1/8" for setting material.
John
ZZZK is offline   Reply With Quote
Unread 05-26-2019, 04:20 PM   #50
Anthocar
Should the plastic box be removed before finishing up or does it stay in?
Thanks for the clarification.
AC
Unread 05-26-2019, 04:58 PM   #51
Usually you would tile within 1/8-1/4 inch outside the plaster guard. If you want to make sure, get the trim out and attach it. I've seen some that leaves plenty room for the trim to fit and others that barely cleared after tiling around the trim guard. Then remove the plaster guard before installing the trim.
Unread 06-11-2019, 03:31 PM   #52
Anthocar
Greenboard over shower?
I had to redo a shower and am ready to replace the drywall in the 8ft ceiling. I was thinking that greenboard would be a good material to use here since it would resist mold and will be exposed to steam from the shower. I plan to texture and paint over the greenboard. Is there a reason I should use regular drywall instead?
AC
AC
Unread 06-11-2019, 03:48 PM   #53
I've combined you again with your project thread for this shower, AC, so folks can see what you're working on and what's been previously asked and answered. A moderator can give it a more generic title any time you'd like to suggest one.
I see no advantage to using one of the MR versions of drywall in that application, but if it makes you feel better there's no technical reason not to do so.
I trust you meant water vapor from your shower when you said it would be exposed to steam. This is not a steam shower, right?
Unread 06-11-2019, 03:51 PM   #54
Anthocar
Great, thanks for keeping everything together CX.
Yes normal steam from a shower, not a steam shower. Thanks for the help this entire project. It's coming along.
AC
Unread 06-14-2019, 08:07 PM   #55
Anthocar
How do y'all transition the backer board/drywall seam? I was thinking about getting it perfect using joint compound and then throwing a coat of redgard over the finished seam.
Thoughts/advice?
AC
Unread 06-14-2019, 09:21 PM   #56
tatumjonj
I'm pretty sure what you're seeing with those staples is the staple "installed" in a patch and the patch glassed to the already set up enclosure. The staple never pierces the actual enclosure, just the patch.
Two things give it away. You can clearly see the staple behind the patch which would not be as clear if it were behind a lot of layers of glass and you can see the air bubble in the patch where it was placed over already dried glass.
Jon
Unread 06-14-2019, 09:24 PM   #57
I'm not a fan of having joint compound on the wet side of the seam so I would mud the seam with thinset and tape. Then after the shower is tiled you can add a skim coat of compound mud over the thinset on the dry side of the seam.
Unread 07-15-2019, 09:57 PM   #58
Anthocar
Not sure if we post after pics. Thought y'all Might want to see the tiled shower. Thanks for the help.
AC
Unread 07-16-2019, 06:07 AM   #59
Nice and clean, AC, good job.
What's going on the left side though?
Unread 07-18-2019, 08:38 PM   #60
Anthocar
Thanks man!
The bathroom is tiny and the shower will be caulked against the door trim on that side.
AC
Tile Over Fiberglass Deck deepwater28 Professionals' Hangout 2 11-08-2013 06:27 AM
Fiberglass shower pan icedT Tile Forum/Advice Board 10 10-23-2007 08:01 PM
fiberglass shower pan Q's ashleykremm Tile Forum/Advice Board 18 12-23-2006 11:43 PM
8'x4' new shower => fiberglass pan? jfbailey3 Tile Forum/Advice Board 23 09-01-2005 09:06 PM
mud pan in fiberglass shower pan corny Tile Forum/Advice Board 2 12-16-2003 07:55 PM
