Unread 05-14-2019, 09:37 AM   #1
Diana07
shower tile stays wet up to 24 hours
I'm not a tile person and I may be on the wrong forum. My problem is my shower. My shower tile can stay wet up to 24 hours. I have had tile showers before, they usually dry up within an hour or two. My builder claims it isn't a problem. They tell me that I have a Kerdi system. I was getting some white build up in one area. (looked like calcium) they came back and re-caulked the seams. Any advice would be greatly appreciated.
Diana
Diana07 is offline   Reply With Quote
Unread 05-14-2019, 02:22 PM   #2
rmckee84
rmckee84's Avatar
We'll need some more info, like exactly what products and materials were used. Pics of the current issue and of the install while it was being built would be helpful.
Ryan McKee
Unread 05-14-2019, 02:36 PM   #3
e3
is there a slope toward the drain from each corner?
Eric
Noble Company
Unread 05-14-2019, 06:16 PM   #4
Elkski
Elkski's Avatar
Do you have a shower door, do you live in humid climate? How is it wet? Wet look? Water in grout lines? Were there cracks before they recaulked? Recaulked where? I'm not a tile pro but these are questions i had.
Teddy
Unread 05-14-2019, 06:41 PM   #5
Do you keep the shower door closed after using it? If so, that will keep it from drying out. You might need more ventilation in this bathroom.
shower floor stays wet rbat61 Tile Forum/Advice Board 4 02-27-2011 12:23 PM
New shower install - grout gets and stays wet- even though sealed FlynHokie Cleaning, Restoration and Sealing 43 10-05-2010 11:52 AM
Kerdi Shower - How many hours? bathroomremodeler Professionals' Hangout 2 02-23-2008 05:10 PM
Grout at perimeter of shower pan stays wet. cecpad Tile Forum/Advice Board 1 02-21-2007 10:26 PM
Shower weep holes - so the stuff stays in there forever? Boris Tile Forum/Advice Board 2 03-19-2004 10:09 AM
