Old 02-15-2018, 09:22 AM   #1
benualson
floor prep advice
Bought a 1954 ranch to remodel and move my family into.
Currently, we've pretty much gutted the main level. The only thing touching the subfloor right now are the stud walls and exterior walls. There is 1/2 plywood on the 16 OC floor joists on the entire 1600 sqft of the main level. It isn't T&G. It is nailed down. About 40% of it is dirty with residual adhesive and a but of damage from scraping up old flooring/adhesive.
We want to put hardwood floor down in most of the area and tile in the bathrooms and entry areas.
So, I want to prepare the entire 1600 sqft for those applications.
Reading through this forum, I'm not sure what I should do.
I'm thinking of laying down 3/4" T&G plywood over the entire 1600 sqft. I'm not certain what the best way is to fasten it to the floor.
I'm not sure if I should just install the new T&G as a subfloor (install it as though the existing 1/2 subfloor is not there).
Or, if I should install it as an underlayment (with possibly wood gluing/laminating the entire thing) while following this pattern:
http://www.johnbridge.com/images/mik...-0604.pdf..pdf
Any advice would be appreciated,
benualson is offline   Reply With Quote
Old 02-15-2018, 05:28 PM   #2
Welcome back, Ben.
If you're not prepared to remove the existing subflooring, that would be my first choice. Be sure your fasteners are long enough to penetrate the joists by a minimum of 3/4-inch.
Old 02-15-2018, 09:37 PM   #3
benualson
I'm probably in a good position to remove the existing subfloor. Do you just cut it up to the stud walls? Then add blocking to support the new subfloor at those edges?
Sent from my ONEPLUS A5010 using Tapatalk
Ben
Old 02-19-2018, 11:18 PM   #4
benualson
I've talked to a couple contractors to bid the job of installing 3/4" t&g plywood over the existing 1/2". Both say they would lay it opposite the 1/2" layer (parallel to joists). I assume that is a red flag and I should keep looking for someone who knows it should go down perpendicular to joists?
If I cannot, I'll just have to man up and diy it.
Ben
Old 02-20-2018, 10:28 AM   #5
rmckee84
rmckee84's Avatar
Yep, red flags for sure. All layers should run perpendicular to the joists.
Ryan McKee
Old 02-20-2018, 05:43 PM   #6
Another major installation error is to never have four corners line up...the sheets should be offset. The ply (and OSB) has quite different stiffness characteristics, and needs to span the narrowest supports, not run along them.
Old 02-21-2018, 05:48 AM   #7
benualson
Glue or no glue? Fasten in field as well?
I'm thinking the answer to both of these is a no.
Should I get Avantech?
Ben
Old 02-21-2018, 01:33 PM   #8
No glue, and just fasten to the joists as though the 1/2" plywood isn't there. I'd recommend 2 1/2" screws or longer, and deck screws only. No sheetrock screws.
Advantech is fine.
Old 02-28-2018, 11:10 AM   #9
benualson
so we are saying to fasten to the joists as though the 1/2" plywood isn't there. Does that mean my 4ft ends should meet on a joist? Currently if I just lay a sheet down it would be 4 inches past the joist. (16OC)
No such thing as a stupid question, right?
Ben
Old 03-02-2018, 01:42 PM   #10
benualson
Any thoughts on my previous message? Also do I need to prep the existing floor besides vacuuming it?
Ben
Old 03-02-2018, 08:13 PM   #11
Phatteus
Page 18 of the 2018 Schluter Ditra installation manual gives detailed instructions of how to add a second layer of subfloor to an existing one. It may be helpful in your situation and is available as a PDF online.
Tyler
Phatteus is offline   Reply With Quote
Old 05-13-2019, 07:53 PM   #12
benualson
new tile job with grout cracking
I am remodeling my house before we move in. Been a long many months. Joists are 2x10 16OC. There was original 1/2 plywood subfloor. We added 3/4 t&g adventech on top of that screwed into joists. I hired a guy to do tile work. They did ditra then tile. After a couple weeks I am having crack lines in grout and some loose tiles. I remember it being really hot in the house the day they did the ditra. I walked in and it was so hot and humid. This was middle of winter. The heat was turned up to like 88 or something. Anyway, I'm just frustrated. They came and fixed the problems a couple weeks after install but now a few weeks later I am having the same problems. I feel like I need to tear it up and start over.
Sent from my Pixel 2 using Tapatalk
Ben
Old 05-13-2019, 08:08 PM   #13
I've combined you with your original thread on this floor, Ben. I looked back to see if you ever told us the unsupported span of those joists and I don't see that you did so let's start there.
What is the unsupported span of your floor joists?
Old 05-13-2019, 08:09 PM   #14
Welcome back, Ben.
Is this the same project as this one?
Can you tell us what mortar was used, both in the installation of the Ditra underlayment and the tile?
Also, if you know, what size trowel was used for both of those applications?
What size tile?
Heat can accelerate the drying process, often to a poor outcome. Was there sunlight directly on any of the floor during the installation? Were fans running in the area?
Old 05-13-2019, 08:10 PM   #15
I also see we missed your last question about the installation of the subfloor. How was that installed?
New Tile grout cracking jcork Tile Forum/Advice Board 2 09-06-2012 04:05 PM
All my Ceramic is cracking, grout is cracking....HELP!!!! rickincanada Tile Forum/Advice Board 11 04-14-2009 10:13 AM
Grout cracking in new tile please help? bstroman Tile Forum/Advice Board 17 04-07-2006 05:07 PM
Tile grout is cracking norah Tile Forum/Advice Board 2 01-14-2006 08:33 PM
Tile over plywood grout cracking Alex H Tile Forum/Advice Board 23 10-01-2002 05:01 PM
