Old 05-12-2019, 08:02 AM   #31
DragonQueen
So approximately how thick from the 3/4 t&g would these layers be, thinset, ditra, thinset and 10mm tile? 3/4 of an inch? 1inch? Just trying to see how much of a raise and if I can deal with or scrap the whole thing.
Carie
DragonQueen is offline   Reply With Quote
Old 05-12-2019, 10:55 AM   #32
PC7060
PC7060's Avatar
10mm is little more than 3/8”; Ditra is 1/8”; figure 3/16” thinset all total, come up to around 3/4” in addition to the plywood.
Did you mean the 3/4 plywood over the T&G?
Old 05-12-2019, 09:27 PM   #33
DragonQueen
On top of the t&g. Thanks
Carie
Old 05-12-2019, 09:34 PM   #34
I'm confused, too, Carie. You have sawn boards as your first layer of subflooring. That may be T&G material, but we don't know that. Then you have installed nominal 3/4" plywood over that sawn board subfloor, yes? The plywood does not need to be T&G in that application, but it can be if you want.
Now, you are talking about installing your Ditra and tile over the plywood, yes?
Old 05-13-2019, 06:15 AM   #35
DragonQueen
Yes, sawn boards, 3/4 t & G, ditra, tile. The sawn1x4 are not t&g you can see them from the basement. To many spots that you can see slivers of other stuff. We had the carpet up in one of the other rooms years ago. Thought I needed t&g for the 2ng layer cause the original subfloor is the diagonal sawn boards?
Carie
Old 05-13-2019, 06:26 AM   #36
DragonQueen
So I can do, sawn 1x4, 3/4 ply bc face or better screwed to sawn boards, ditra modified thinset to ply, tile to ditra unmodified thinset?
And the modified thinset needs to meet the.
. 11 standard
Carie
Old 05-13-2019, 08:00 AM   #37
You're counting on the board subfloor to support the edges of the second plywood layer. If you can get the T&G plywood in there, that's fine, but you'll find that to be another problem.
You must orient the plywood with the face grain perpendicular to the joists and you're gonna need to pre-drill all the screw holes in the plywood before installation to prevent screw jacking.
See my warranty information below.
Old 05-14-2019, 07:01 AM   #38
DragonQueen
OK hubby can handle that.
So back to the portion of shower wall next to toilet, drawing on page 2. Anyone have opinions or improvements on that wall?
Carie
Old 05-15-2019, 10:43 AM   #39
DragonQueen
OK so how about this change, not going for curbless necessarily, as minimal as possible curb will work. On the end wall next to the toilet, using a narrow glass pane for the corner in the section of the window. Seal it to the wall next to the window? Or have the c channel go in a u shape on the top and sides instead of an L shape on the bottom and interior wall side?
Not sure where on the drain offset or centered, if I can get 6x6 tiles I like the spot drain will go in.
Carie
Old 05-16-2019, 07:59 AM   #40
I feel like the 18" opening to the shower is really narrow, Carie. The minimum may vary by location but I think I read somewhere that 22" is minimum in my area. A moot point if you're not having it inspected, but even if not 18" is pretty tight.
Old 05-16-2019, 08:25 AM   #41
PC7060
PC7060's Avatar
Dan is correct; 22 shower opening is minimum allowed by code.
Old 05-16-2019, 09:17 AM   #42
I've built a number of doorless, curbless showers with openings less than 24 inches, Carie, but even I'd balk at an 18-inch opening. That's getting a bit tight for even medium-large persons.
Old 05-16-2019, 06:17 PM   #43
DragonQueen
OK that is fixable, anything on the rest?
Carie
Old 05-17-2019, 01:22 PM   #44
DragonQueen
So how bout this one? The entry is a 22" min around here also thanks. However that doesn't leave room for any kind of corner though unless anyone has any ideas?
Carie
Old 05-19-2019, 05:58 PM   #45
DragonQueen
So hubby read thru what I had, he does want to bring the toilet to code. So we now have this floor plan option. I still don't want a door on the shower even though he has one there. He does have the adjoining hallway and closet on this drawing.
Carie
Small Bathroom Remodel gslenk Tile Forum/Advice Board 188 08-31-2019 08:21 PM
PK's 5x7 Small Bathroom Remodel - almost done pktaske Tile Forum/Advice Board 104 04-15-2012 11:00 AM
Jim's Small Bathroom Remodel JimInStLouis Tile Forum/Advice Board 35 05-06-2010 01:57 PM
small bathroom remodel ricky57 Tile Forum/Advice Board 16 12-07-2007 04:03 PM
Small Bathroom Remodel dcgauger Tile Forum/Advice Board 6 01-09-2004 04:26 PM
