Unread 03-26-2019, 06:57 PM   #1
demolish50
Is this Efflorescence?
That white material on that stone exists throughout this floor. It's less than a month old in a new construction home. The obvious white stone in the picture is by far the worst. It doesn't come up. Vinegar, Dawn, etc don't budge it, even with a metric ton of elbow grease.
You can feel it with your fingernail when you rub your finger across the stone however it will not come up.
The pic was taken about 20 minutes after use.
Thoughts?
Justin
demolish50 is offline   Reply With Quote
Unread 03-26-2019, 07:27 PM   #2
Welcome, Justin.
What is the application?
What was the "use" 20 minutes prior?
With what bonding mortar were the stones set?
Over what substrate?
Unread 03-26-2019, 07:30 PM   #3
demolish50
Hey, thanks.
It is a shower floor.
The shower was used That's why it looks a bit wet.
Unknown. It is a new construction home. Was not custom.
I'm sure there is a pan on top of a cement foundation.
Justin
Unread 03-26-2019, 08:15 PM   #4
And to be clear, this whit spot was not present, or not apparent, before the shower was used?
Unread 03-26-2019, 08:28 PM   #5
demolish50
Used as in never used before? I don't recall it looking like this prior to us moving in.
This has slowly gotten worse over the past 30 days since we moved in.
Justin
Unread 03-27-2019, 05:29 PM   #6
I'd scrape at it lightly with a single edge razor blade to see if that removes it. Then, give it more time to see if it shows up again or on other stones. It's really hard to tell from looking at one stone.
possible efflorescence chemprof Tile Forum/Advice Board 35 04-23-2019 05:49 AM
Efflorescence Jellieb Cleaning, Restoration and Sealing 1 10-04-2010 11:51 AM
efflorescence? kevjob Cleaning, Restoration and Sealing 9 12-29-2009 01:52 PM
Efflorescence? Davery Tile Forum/Advice Board 6 06-06-2006 08:17 PM
efflorescence erikjo Cleaning, Restoration and Sealing 32 10-15-2005 09:08 PM
