Old 03-17-2019, 03:25 PM   #16
John, best you post a photo of what you've got. I'm confused by your descriptions.
Use the paper-clip icon above the Reply dialog box to attach photos from storage on your computer.
Old 03-17-2019, 03:28 PM   #17
Jonnyshark
Problem solved, thanks for your help.
My fault, bad cut on foam tray.
John
Jonnyshark is offline   Reply With Quote
Old 03-18-2019, 10:02 AM   #18
Jonnyshark
1/8 inch Slope fix?
My plywood sub-floor has an 1/8 inch slope lengthwise 36x60. I'm installing the kerdi shower tray with center drain and curb. Recommendations on leveling sub floor?
*Could I use 1/8 shims pressed into the thin-set?
* Self leveling compound, Fill the whole pan? Particular brand from Loews or Home Depot?
Thank you!!!
John
Old 05-22-2019, 12:26 PM   #19
Jonnyshark
Wall tile gap between floor tile advise
I'm looking for advise on a solution for the 1/2 inch gap between the last row of tile and the floor tile. I tried this morning adding extra thin-set and it made a mess and ruined 4 sheets of 2x2 floor tile.
For reference i placed a few individual floor tiles down.
I headed up to the local tile store for some advise.
Ideas???
Feather thin-set or mud bed to fix the gap?
Build a perimeter on the floor of extra wall tile?
John
Old 05-22-2019, 05:50 PM   #20
tatumjonj
Why did you set the bottom row without laying the floor first?
Jon
Old 05-23-2019, 06:25 AM   #21
I don't believe it matters at this point, Jon, does it?
John, how thick is the floor tile? Do you have a 1/2" around the entire perimeter of the floor?
Old 05-23-2019, 07:20 AM   #22
speed51133
What's with all that green stuff on the Kerdi?
How exactly did you construct this shower? That drain doesn't look quite right...
Kerdi screw-up... modified thinset msavold Tile Forum/Advice Board 5 11-06-2010 07:30 AM
Kerdi Question (AKA how bad did I Screw up) mwpfop Tile Forum/Advice Board 91 01-01-2009 11:59 AM
Did I just screw up? Flexbond & kerdi agchoset Tile Forum/Advice Board 7 04-26-2007 09:39 PM
Screw Kerdi... BradH Tile Forum/Advice Board 39 11-28-2006 05:34 PM
Kerdi with Screw-on Grab Bar awmatt Tile Forum/Advice Board 3 08-09-2004 03:51 PM
