Unread 05-23-2019, 12:57 PM   #121
If you screwed the ledger to the wall, then set the 1st row, I'd leave the ledger up and keep on tiling.
If you tacked it on with finishing nails from an nail gun, as I did mine, I'd let that 1st row set for a couple of days.
Unread 05-23-2019, 02:50 PM   #122
SpaceCadet
I propped the ledger board up on bits of wood, plastic horseshoe spacers, and cardboard drywall shims, then asked my wife not to do jumping jacks in the kitchen next-door.
Paul
SpaceCadet is offline   Reply With Quote
Unread 05-24-2019, 05:58 AM   #123
No used chewing gum?
Yea, I'd wait a couple of days for that 1st row to set.
Unread 05-24-2019, 09:47 AM   #124
Double Bubble works best. I usually make a small level mud screed after mudding my walls. That gives me a level ledge to set my first row on and also gives me a level perimeter ledge for mudding my floor. But, in your case I would screw in the ledger board in place of the bottom row making sure I hit the studs. If a pan liner is used, we may go up a row or two to avoid holes in the liner. Then tile the whole wall. On a tub surround I would set the ledger boards and tile all three walls then cut in against the tub the next day. It's different for a DIY'ers, we don't have time to let the bottom row set before tiling up the wall.
Unread 05-24-2019, 11:58 AM   #125
SpaceCadet
I'm here to set tile and chew bubble gum and I'm all out of bubble gum.
Since it's a long weekend and I've got time, I think I'll set as many rows up from the ledger as I can and leave the ledger in place until the next day at least.
There's a window in that wall and the top of the opening cuts slightly into the top row of 12" tile. So there's nothing below part of that row and just the ceiling above it so I can't rest it on tiles beneath or tape it to tiles above. Is there a way to secure those tiles while they set? My best idea is spanning the window opening with a piece of aluminum angle and propping the tiles up on that.
Paul
Unread 05-24-2019, 12:37 PM   #126
If you feel like your ledger board supports are solid and won't shift, start stacking those 12X12's, but I'd still be a bit concerned about it "rolling" away from the wall once some weight is on it.
Regardless, I would lay your longest level across each row you stack. Although my 12X24's are rectified and very consistent, they aren't perfect. Laying my 6.5' level atop each row allowed me to tweak any that needed to be tweaked with wedges.
As for the window - gotta pic?
Unread 05-24-2019, 07:38 PM   #127
SpaceCadet
I don't think the ledger will roll away. The ProLite is doing a good job holding things to the wall. The tiles slide down some but don't pull away from the wall so the pressure is straight down. A lot of the weight is held up by the mortar too. Doesn't look like I can manage more than 10 tiles in one go anyway, takes me too long to work them into the mortar so they're lined up depth-wise, so there probably won't be more than 2 rows over that board for a while.
There's an old picture of the wall with the window here: https://www.johnbridge.com/vbulletin...6&postcount=52
Paul
Unread 05-24-2019, 08:57 PM   #128
Dan can correct me but I think he is talking about the ledger board pulling away from the wall at the bottom. This sometimes happens when you add more weight, the supports under the board slide on the tub. Screws into the studs will keep this from happening.
Unread 05-26-2019, 08:45 AM   #129
SpaceCadet
The 2x4 the ledger rests on the flat parts of the tubs at either end. It's pretty stable. Anyway, I only managed to get one row up over it in a reasonable time.
What am I doing wrong? It takes me 2 hours to set 5 tiles. The time before that, I near the pot life limit of 4 hours and managed 10. I do go slow and try to get everything perfect but that's way too long. Burn mortar on the wall. load up a thick layer of mortar and comb out the notches, backbutter the tile, press the tile in, wiggle it into place until it's level with neighbors+level+plump+karmically copacetic. I check things with a spirit level and straight edge, and slide a horseshoe spacer over the gap back and forth (sharp corner side to tile). The sliding spacer can click but not too much and can't get stuck.
I'm already using a pretty big trowel, 1/4x1/2x1/4 u-notch, and I try to err on the side of too much. I'd rather have to spend more time working the tile in and cleaning up mortar oozing from the seams than have to pull it off and add more mortar. I keep a mallet handy but don't use it much, mostly just wiggling the tile.
Does it sound like I'm doing something wrong or just fiddling too much?
Paul
Unread 05-27-2019, 06:43 AM   #130
If it makes you feel any better, Paul, it took me about 6 hours to set only 20 linear feet of tile baseboard, though that did include cutting a bunch of tile.
But I don't guess it does.
You're process seems good, though if it were me I'd forgo burning a layer onto the wall. I think I'd also set an entire row, getting them close, and then use your level and straight edge to adjust them. I really like the hard plastic wedge spacers I bought, they're great for very tiny tweaking.
Unread 05-27-2019, 08:26 AM   #131
Like Dan, I also like plastic wedges. The tiles vary slightly in size so the wedges help fine tune the tiles.
Check your substrate for flatness and know where any humps are before you tile that area. The extra cushion of thinset will thin out over a hump keeping the tiles flat.
Don't get impatient, continue to check the tiles with your level on the top edge of each row along with the face of the tiles. You'll get faster as you go.
Unread 05-27-2019, 09:26 AM   #132
SpaceCadet
Thanks. 20 tiles in 6 hours still has me beat. Although I go faster with smaller tiles. I set the 25 sq ft of plank floor in a total of 4 hours but that didn't come out so great.
What brand wedge and horseshoe spacers do you guys like? The brutus horseshoes I got are pretty good but the mold marks can be prominent. On the bright side, I can rummage around in the bin and find a slightly thicker/thinner one to tweak a seam when I need to.
Paul
Unread 06-02-2019, 09:12 PM   #133
SpaceCadet
If you have a raised area on a wall, can you grind the back of a tile to clear it and keep that tile in plane with its neighbors? These are 12x12 porcelain tiles 3/8" thick. I zigged where I should have zagged and ended up with a tile sitting on a thin layer of mortar next to a raised area (fabric embedded in waterproofing and mortar+mesh at CBU corners). The raised area already has tiles to one side and below so if I tilt a tile up onto the hump, it's bound to get lippage somewhere.
Paul
Unread 06-02-2019, 09:36 PM   #134
I've had to do that a couple of times when I wasn't paying attention like I should have been. It's not ideal, but it can work.
The key is to make sure there's still full contact between tile, mortar, and substrate. Since the tile will be thinner, and therefore weaker, you don't want to risk it breaking due to lack of contact.
Unread 06-16-2019, 07:48 PM   #135
SpaceCadet
I've got 3 12"x12" tiles to set between the ceiling and top of the window. 2 of them are supported along 1/3 of the bottom but the one in the middle is above empty space.
What's a good way to support the tiles while the mortar sets? I've got some ideas but I'm probably overthinking it.
Paul
Jason's Small Shower Rebuild wkumtrider Tile Forum/Advice Board 132 05-09-2017 01:50 PM
starting bathroom rebuild efjellanger Tile Forum/Advice Board 37 12-16-2013 10:42 PM
Bathroom Gut & Full Rebuild. GreatWhiteNowhere Tile Forum/Advice Board 2 04-30-2012 09:26 AM
Bathroom rebuild - gonna have some questions sdl Tile Forum/Advice Board 5 11-25-2011 01:11 PM
Help!...Demolish/Rebuild Small 35-yr-old Bathroom sinkholed Tile Forum/Advice Board 54 08-04-2007 09:14 AM
