Old 12-20-2018, 11:55 AM   #16
speed51133
Old 12-20-2018, 12:17 PM   #17
AEN3MA
Sorry, I'm probably not describing this right. There will be tiles in the shower floor. I need to make a shower tray. Some shower Tray's/Pans come already prefabricated that you can lay tiles over, like the KBRS Tile-Basin or the Schluter Systems Kerdi-Shower-Kit Stainless Steel Styrene Shower Base 60-in W x 32-in L with Center Drain. They are expensive. Do I need to go that route or can I make something myself.
What I am trying to do is below.
I just don't want it to leak to the unit below and my friends warn me the shower pan/tray (whatever you want to call it) is critical. The slope, etc...
Hence why I asked, are you better off buying a prefabricated unit like the KBRS that has everything instead of doing it yourself.
Josh
AEN3MA is offline   Reply With Quote
Old 12-20-2018, 01:10 PM   #18
Welcome. Please change your permanent signature line to a first name for us to use.
By far the least expensive method, and still one of the best, of constructing a tile shower receptor is to start with a properly sloped deck mud bed that perfectly fits the shower footprint and drain location. That can be either two mud beds for a traditional PVC liner construction, or a single mud bed for a direct bonded waterproofing membrane type of installation. Either can be installed over a suitable subfloor without regard to making it perfectly level as is the requirement for all the pre-fabricated foam trays and other such receptors.
We've had hundreds and hundreds of DIY visitors here create such shower receptors successfully.
Old 12-20-2018, 01:30 PM   #19
Topspin
SchluterUgrad
Topspin's Avatar
Hi Josh,
CX is correct, most people have done the pan liner method in the past. However, I have not done one since 2006 and do about 12 to 15 showers a year ever since using a surface applied waterproofing membrane. I find that infinitely easier and less prone to mistakes than the liner method.
For a quick video to show how you can do a mud bed with, in this case a linear drain, see the following link for a very simple mud bed by Laticrete. https://m.youtube.com/watch?v=NLzYA79OV20
I’ve used Laticrete Hydro ban, Kerdi, pre-formed shower pans by Schluter, Laticrete and Wedi. But just doing a mud bed costs almost nothing and doesn’t take very long. And even if you made a start-over mistake, it would cost you about $15 in materials and a few hours time to redo. ( not including your waterproofing membrane material top layer)
If you go to Laticrete’s website I am sure they have additional videos on doing a center drain mud shower pan as well.
Old 12-20-2018, 01:52 PM   #20
AEN3MA
What is the difference between a linear pan method (mud) and a surface applied waterproofing membrane? Don't you need the mud pan regardless?
I'm a bit confused, isn't the pan the foundation that you need?
Josh
Old 12-20-2018, 02:07 PM   #21
speed51133
the traditional liner pan is packed mud with a slope to the drain. then you lay your PVC membrane. then you pack ANOTHER mud slope on top of the PVC liner. this is essentially called a preslope and a slope.
https://www.google.com/url?sa=i&sour...45422775909821
surface applied membranes only have one mud slope, then the surface membrane.
https://www.diychatroom.com/attachme...erdidrain2.jpg
OR, you can buy a foam pan like KBRS or schluter that takes the place of the single mud slope.
Old 12-20-2018, 02:42 PM   #22
AEN3MA
Thanks Mike, that was helpful.
Josh
Old 12-20-2018, 05:26 PM   #23
Topspin
SchluterUgrad
Topspin's Avatar
The reasons why I changed to the surface applied membranes is because I don’t like following all those rules. No penetration is below a certain point, weep hole protection, pack a perfect mud bed, then put a rubber liner and then pack another mud bed on top? Glue on corners that are thick rubber, notching out studs for folded corners or trying to adapt to walls that flare out at the bottom: packing a curb on top of the rubber liner with no nails, it’s all a lot of work.
I know I am exaggerating it but a liquid applied waterproofing method basically forgets all those rules. Pack one slope, you’re done with that. Put your waterproofing on properly and you are done. Using Schluter Kerdi - parts of it can be even easier, some parts have a little bit of work in the corners.
The kind of questions you are asking gives me the impression you are at the very start of this process so take a little time to learn the benefits of today’s most innovative products and the method of installation and you might find something you like better than the liner traditional mud pan.
And if you were going to be using some type of preformed pan you are going to be using a liquid membrane anyways so you might consider looking at going that route with a simple to build mud pan.
Or if you are set on doing a preformed pan, for example a Schluter Kerdi shower pan is only about $100
https://www.amazon.com/Kerdi-Shower-.../dp/B00EKU0VPA
Old 12-20-2018, 06:34 PM   #24
AEN3MA
This is very confusing. Seems like there are multiple ways to skin a cat.
Josh
Old 12-20-2018, 06:35 PM   #25
There are.
If you're looking for a short answer about which one to do, I would advise going with a surface-applied membrane, specifically a sheet membrane.
Old 12-20-2018, 06:59 PM   #26
AEN3MA
Is this method pricey? Which is the must budget friendly method? and which is the overall easiest method for a beginner like myself?
Josh
Old 12-20-2018, 07:18 PM   #27
That requires two different answers.
The least expensive is the conventional liner and two mud beds, plastic on the studs, and cement boards. But it also has a number steps and if you miss any of them, you could have a leak.
The surface applied membranes require one sloped mud bed and the waterproofing layer. Not much else to it. It is more expensive, but not so much that it's not worth it.
If budget is the only consideration, go with the PVC liner, but be prepared to follow every step to the letter.
Old 12-20-2018, 07:21 PM   #28
AEN3MA
Does the top layer or Mud layer (bottom) have to be sloped If I'm going the mud route?
Josh
Old 12-20-2018, 07:38 PM   #29
Any mud layers you have in a shower must be sloped a minimum of 1/4 inch per horizontal foot from the drain to the farthest corner of your shower. The tile surface would, then, be sloped the same. The perimeter of the mud bed(s) should be level all the way around.
Old 12-20-2018, 09:38 PM   #30
AEN3MA
Thanks for all the help people. I'm learning through this thread.
So let me get this straight.
If I were to buy the Kerdi Shower Tray (like the one pictured below), which step does that remove from the mud method.
From my understanding, in the mud method, you have to mud, liner over that, mud 1/4 slope. Please correct me If I'm wrong.
With this tray, does it remove all of those steps? Or do I first have to mud, then lay that tray.
Josh
spacers or no spacers for subway tile T@StPete Tile Forum/Advice Board 5 07-27-2015 07:18 AM
Tile Spacers Gunner Tile Forum/Advice Board 6 03-20-2008 09:50 PM
What size tile spacers to use on bathroom walls ruben7566 Tile Forum/Advice Board 3 05-09-2006 06:50 AM
better tile spacers tilesnake Professionals' Hangout 21 02-24-2004 11:36 AM
Re-Using Tile Spacers Robert Villa Professionals' Hangout 12 10-25-2002 10:33 PM
