Unread 02-10-2009, 09:40 PM   #1
lefty33
lefty33
corner bead?
Im using hardibacker for the walls of my shower. I will tape and mud the inside corners. but does anybody use corner bead on the outside corners. like in the door way corners. if not what do you do to the corners.
Lefty
lefty33 is offline   Reply With Quote
Unread 02-10-2009, 09:54 PM   #2
RedRock
Granite, Quartz, and Tile Installer
RedRock's Avatar
If the corners are going to be tiled then use backerboard mesh tape and thinset - just like you would do on all the other seams.
Juan
__________________________
You are never too old to set another goal or to dream a new dream. - C. S. Lewis
RedRock is offline   Reply With Quote
Unread 02-10-2009, 10:25 PM   #3
muskymike
muskymike's Avatar
Hi Lefty, what Juan said.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 02-11-2009, 06:02 AM   #4
ddmoit
ddmoit's Avatar
Lefty!
Dan - a DIYer in SE Tennessee
Brian's master bath remodel bhusk Tile Forum/Advice Board 19 04-10-2009 07:17 AM
Corner Bead over sheetrock, under kerdi, tile JohnP Tile Forum/Advice Board 2 04-03-2007 08:42 AM
corner bead lisaA Tile Forum/Advice Board 18 11-06-2005 10:49 AM
Corner Bead and Cement Board kidtricky Tile Forum/Advice Board 3 07-07-2005 01:58 PM
corner bead on outside edge Richard S Tile Forum/Advice Board 2 05-08-2005 10:42 AM
