Unread 05-28-2006, 11:16 AM   #1
rockjet
isulpink or fiberglass insulation?
hi...on the outside exterior shower/bath wall---can i use a foam board type insulation or the typical glassfiber roll?;;;r15 ok?.....the board seems nice and easy and less messy................thanx................ mike
rockjet is offline   Reply With Quote
Unread 05-28-2006, 12:19 PM   #2
Turangi
Mike, I wonder if the foam board would also act as a vapor barrier and you would end up with a double barrier situation if you also place one behind your substrate? Perhaps more details of the shower construction would help the pros here. John.
Turangi is offline   Reply With Quote
Unread 05-28-2006, 01:09 PM   #3
Mike2
If you are down in the basement up against a concrete foundation, foam board might have some advantages. Otherwise, I'd go with twice the R-value that batts or a roll product can provide.
