Unread 03-22-2020, 07:52 AM   #1
jameshowison
Ditra XL next to Ditra Heat Duo? Matching thickness?
I'm doing Ditra Heat Duo and I have some Ditra XL left over (like 100 sq ft). I'd like to use the Ditra XL in the areas I'm not heating (with a path of Ditra Heat Duo to the thermostat).
Any insight on whether I can have these next to each other (butting directly) without lippage issues?
Schluter's site seems to list both of these at 5/16", but for Ditra XL the datasheet shows 7mm, and for Ditra Heat Duo it shows 8mm ...
It'll be on a reasonably level concrete sub-floor.
James Howison
jameshowison is offline   Reply With Quote
Unread 03-22-2020, 08:59 AM   #2
Hi James,
A difference in height of one millimeter won't hurt you. Go ahead and use the two products.
Unread 03-23-2020, 01:22 PM   #3
jameshowison
Thanks John. Well, well I pulled it down it was Ditra regular, not XL, so a much bigger difference. And not nearly as much as I remembered anyway
James Howison
Mixing Ditra Heat & Strata Heat components jutsin Tile Forum/Advice Board 5 01-10-2019 10:19 PM
Ditra/Ditra Heat Hybrid? RRGuy Tile Forum/Advice Board 6 07-14-2016 07:25 PM
Ditra Heat Comments in Regards to Floor Heat matthewstephanie Tile Forum/Advice Board 9 03-17-2016 07:37 PM
Heat, Ditra and Thickness gordonyee Tile Forum/Advice Board 3 07-20-2010 06:35 PM
Ditra XL on Concrete - Matching up Tile To Engineered Iristyle Tile Forum/Advice Board 4 09-19-2009 07:53 AM
