Unread 01-27-2020, 06:21 PM   #1
Just In Tile LLC
Just In Tile LLC's Avatar
Rough-In drain close to the wall
My question being when you want to have a linear drain that is basically flushed up with the finish wall tile and use the kerdi system, the flange seems to be too big to get the whole assembly close enough to the wall. Do they make a specialized drain assembly for close quarter drains or am I not thinking this through correctly?
Justin
Unread 01-28-2020, 09:38 AM   #2
houndzilla
is this a Schluter drain? or a different product?
George
houndzilla is offline   Reply With Quote
Unread 01-28-2020, 12:36 PM   #3
Hi Justin,
Looks to me like the flange will fold right up the wall on the wall side. https://www.schluter.com/schluter-us...E/p/KERDI_LINE
Unread 01-28-2020, 12:46 PM   #4
Just In Tile LLC
I haven’t seen something like that John, but what about the actual round disk part that gets installed over your plumbing stub out?
It is a kerdi round drain Houndzillla, I just can’t figure how that round disk gets that close to the wall to get a linear drain installl flush to the the finish wall.
Justin
Unread 01-28-2020, 12:58 PM   #5
speed51133
you dont use the round bonding flange. you use this
Unread 01-28-2020, 01:10 PM   #6
Just In Tile LLC
What’s the minimum distance from the stud to center of the stub out on that Mike?
Justin
Unread 01-28-2020, 01:15 PM   #7
Just In Tile LLC
Or maybe even the distance from pre-tiled wall to that stub out?
Justin
Unread 01-28-2020, 01:22 PM   #8
speed51133
https://www.schluter.com/schluter-us...-wall-distance
How far from the wall is the KERDI-LINE linear drain installed?
Directly against the wall, so that the channel body support is in contact with the wall. The drain outlet is approximately 2 1/8" o.c. from the edge of the wall board.
Unread 01-28-2020, 01:22 PM   #9
Just In Tile LLC
And by the way that is exactly the product I was looking for. Could not understand how I’ve been seeing these tighter quarter drains with the traditional flanges.... unless they were cut.
Justin
Unread 01-28-2020, 01:23 PM   #10
ItchyVols
They’re just under 3” wide so shouldn’t be more than 1.5” from center of drain to the edge.
https://sccpublic.s3-external-1.amaz...ta%20Sheet.pdf
Bradley
ItchyVols is offline   Reply With Quote
Unread 01-28-2020, 01:24 PM   #11
Just In Tile LLC
I appreciate the quick info Mike and John
Edit: And now Bradley
Justin
Unread 01-29-2020, 05:44 PM   #12
Tiger Mountain Tile Inc
Look into the Noble freestyle drain. It's meant to butt right up to the wall and the drain pipe glues into the drain so you don't have to worry about those hose clamp thingies.
Jim Upton
Curious how the new Delta Cruzer tile saw stacks up against Dewalt? Check out the full review and video on DIYTileGuy
rough in for schluter drain rwebb Professionals' Hangout 8 12-10-2009 06:56 PM
Kerdi Drain Rough-in Not The Tile Guy Tile Forum/Advice Board 2 09-23-2009 06:14 AM
Drain Rough in ShowerSam Tile Forum/Advice Board 8 12-14-2007 01:54 PM
Kerdi drain rough-in depth mjwiebe Tile Forum/Advice Board 4 12-06-2005 12:11 AM
Kerdi Drain -- Rough-in Mike2 Reference Liberry :-) 0 10-27-2005 08:52 PM
