Unread 10-01-2019, 06:33 AM   #31
JWOrl
OK right obviously it will be attached to wall before band goes on...overthinking it. Maybe I should take break from this project for a day or two to clear my head.
John
JWOrl is offline   Reply With Quote
Unread 10-01-2019, 06:37 AM   #32
JWOrl
Thanks JadNashua, I'll buy one of those film gauges...
I've seen videos where people either use a trowel, brush or roller apply the redgard...which do you think would be best for someone doing this the first time?
John
Unread 10-01-2019, 10:18 PM   #33
Any of them will work fine, the key is to apply it to the proper thickness. I've always used a heavy nap roller.
And you don't want to roll over the same place repeatedly while it's wet. You'll just be lifting the Redgard from the wall, and reducing the thickness.
Using the wet film thickness gauge will tell you if your technique is working.
Unread 10-02-2019, 05:43 AM   #34
Would also be a good idea to whip the wall board down with a damp sponge to remove any accumulated dust.
Unread 10-02-2019, 12:53 PM   #35
JWOrl
Thanks...I've watched the video online and have ordered a film gauge.
John
Unread 10-02-2019, 03:21 PM   #36
Whip it good!
Unread 10-02-2019, 06:19 PM   #37
Yeah,
Unread 10-02-2019, 08:25 PM   #38
JWOrl
John
Unread 10-03-2019, 05:54 AM   #39
I really need to do a better job of poof reading my posts.
Unread 10-03-2019, 08:06 AM   #40
Just like magic, and "poof" there's another one!
Unread 10-03-2019, 09:05 AM   #41
JWOrl
LOL...I do that all the time texting...then I have to send another text correcting the mistake.
John
Unread 10-03-2019, 10:49 AM   #42
Last one was specifically for Kevin.
Unread 10-03-2019, 12:03 PM   #43
Go back and look at all of mine throughout the past few years, you don't hold a candle to my record.
My favorite was when I was trying to suggest the "divot" method for this guy's shower drain, but my phone suggested the "divorce" method.
Actually, either one will work, it's just that one is a lot more costly.
Unread 10-03-2019, 05:56 PM   #44
A few years ago my daughter and I were texting back and forth and I wanted to thank her so I hit the microphone button on my phone and said "Gracias". I looked down at my phone and had sent her "grassy ass". She got a big laugh out of it.
Unread 10-03-2019, 07:08 PM   #45
JWOrl
My cardboard shims (to use on the studs) arrived...are staples the only acceptable way to attach these to studs? The budget manual staplers in the $20 range have so so reviews and I would prefer not buy pneumatic tool or something expensive for this small job, as I don't know if I'll be using the stapler much in the future after this is completed...
Could nails or screws be used for this instead, and if so what kind? Thanks.
Or would this slap hammer be a good tool for this job:
https://www.lowes.com/pd/Stanley-Ham...E&gclsrc=aw.ds
John
Is it okay to mix durock and hardiebacker together on adjacent walls? fredhead Tile Forum/Advice Board 21 08-31-2012 11:19 AM
Hardiebacker walls over hotmop pan Tom prochoren Tile Forum/Advice Board 3 01-10-2012 08:42 AM
Kerdi Shower Install with HardieBacker Walls mike99 Tile Forum/Advice Board 3 01-01-2009 05:57 PM
Help! cutting hardiebacker to fit curved walls teehee Tile Forum/Advice Board 2 10-12-2006 05:57 PM
Hanging Hardiebacker and tiling walls - leave 1/8 gap or not? WEEKEND BUILDER Tile Forum/Advice Board 3 04-25-2006 10:42 PM
