Unread 07-12-2013, 08:03 AM   #1
Lucy SS
Shower marble threshold water staining
Hi! I'm hoping someone can help. We have marble (emperador light) on our threshold to our shower. Right below our shower door. After 5 years, we now have a discoloration of the marble that is inside the shower area when the door is closed. We have tried to reseal but it does not change (darken) the marble to match the other half. Please see attached pictures. Any ideas on what to do or try?
Lucy
Lucy
Lucy SS is offline   Reply With Quote
Unread 07-12-2013, 11:59 AM   #2
Davestone
Florida Tile & Stone Man
What are you using to clean the shower and glass with?You have probably etched the stone and it needs to be repolished.An enhancing sealer may darken it some and hide it.
http://Davestonestile.com
Unread 07-12-2013, 12:55 PM   #3
Lucy SS
We wash the marble down lightly with a damp cloth when needed. I don't think the issue is with what we are washing it with since the discoloration is only on the side of the marble that is inside the shower when the door is closed. This has to be damage from waterstaining of some sort and i would like to know what can be done to restore it. Thanks.
Lucy
Lucy
Unread 07-12-2013, 03:58 PM   #4
Davestone
You could try some Aquamix heavy duty stone cleaner,or similar product that cleans soap scum from marble.If that is what it is.It could also be minerals from the water.
BUT,if that is soap scum or minerals from the water it would also be on the glass .
My experience with this is people forget using stuff to clean glass and it has etched the stone.
You personally probably can't repolish that stone.Emperador is a difficult stone to polish,it is a dolomite,and not a calcium rich stone.You would need a pro.
Unread 07-13-2013, 03:14 PM   #5
Lucy SS
Thanks for the advice. In your opinion would someone be able to polish this marble in place? As you can see from the pictures we cannot possibly remove the marble threshold without removing the glass shower door and we also don't want to crack the marble.
I appreciate your continued advice!
Lucy
Lucy
Unread 07-13-2013, 04:31 PM   #6
A person skilled in polishing can easily polish that piece in place.
Unread 07-13-2013, 05:03 PM   #7
srosen1
The stone has been degraded by the water pooling on the inside of the door.
It is probably etched and stained as well. The etch can be removed but the staining may be harder to remove. You need a stone refinisher who can re-hone, then try to remove the stain. If the damage and staining can be removed re-polish the step.
stu
srosen1 is offline   Reply With Quote
Unread 07-23-2013, 05:17 AM   #8
samjohnsonus
Red face Re: Shower marble threshold water staining
You can go for a highly effective chemical for cleaning the area your floor or you may just call your local contractor for floor replacement.(Because this may go worse)
SAM
samjohnsonus is offline   Reply With Quote
Unread 07-23-2013, 08:26 PM   #9
doitright
doitright's Avatar
Hi Sam
Please introduce yourself in the Pro Hangout.
In regards to your advice...What are you talking about?
Hi Lucy
As mentioned, the threshold needs to be honed and polished in place. This can be accomplished by a skilled Natural Stone Restoration Artist.
Where are you located? Maybe we can come up with a referral for you.
John Koessler
Caulk staining on marble john246 Tile Forum/Advice Board 4 03-13-2011 10:54 AM
Need Help: Shower Threshold Marble homeguy34 Tile Forum/Advice Board 3 01-16-2009 08:17 PM
Grout staining marble Waverly Tile Forum/Advice Board 9 06-12-2007 06:02 AM
Old brown mastic staining new marble tiles? PaigeCT Tile Forum/Advice Board 9 08-16-2005 04:13 PM
Marble Tile in Shower Absorbing Water mspitalney Tile Forum/Advice Board 9 07-11-2005 05:32 PM
