Unread 05-25-2013, 09:34 AM   #1
donald metzinger
outside wall insulation
Friend is doing a shower alcove, one wall is an outside wall, brick backed by block, old tile had furring strips to the blocks, will use new furring strips, cbu with membrane, wants to insulate the outside wall, I suggested an un-faced thin fiberglass to avoid trapping moisture. Any other suggestions would be appreciated, - Don
don
donald metzinger is offline   Reply With Quote
Unread 05-25-2013, 10:59 AM   #2
tilejoe
tilejoe's Avatar
Rigid foam will work better if the spacing is a furring strip
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Fiberglass insulation on interior wall Eggie Tile Forum/Advice Board 12 05-07-2013 09:09 PM
tile tub surround - i'm stuck - wall insulation has vapor barrier regeisle Tile Forum/Advice Board 13 04-01-2012 12:23 PM
Insulation Brad Denny Professionals' Hangout 3 08-16-2007 10:21 PM
Grey fluffy wall insulation - Asbestos? Dpsinghx Tile Forum/Advice Board 8 01-23-2007 01:14 PM
Insulation on interior wall behind Kerdi? kesslerou Tile Forum/Advice Board 3 02-27-2006 01:24 PM
