Unread 05-23-2012, 04:18 PM   #1
carolyn_haack
Putting Oil Sealer on top of Water based Sealer-Saltillo
Good Afternoon!
I'm a complete and utter tile Newbie, but I asked my contractor to have my porch tile (Saltillo) Oil Sealed as I prefer that look.
Unfortunately, there was an error made, and the tile installer used a Water based Sealer for the initial coat.
Can a switch be made to an Oil Based sealer now, or are those tiles "ruined"?
Any advice you can offer is appreciated!
Carolyn
carolyn_haack is offline   Reply With Quote
Unread 05-23-2012, 05:13 PM   #2
Davestone
Florida Tile & Stone Man
Can you tell us what type of sealer it was,i.e. a topical,or impregnating?Is the tile shiny now?Is this area open to rain?
http://Davestonestile.com
Unread 05-24-2012, 09:20 AM   #3
doitright
doitright's Avatar
Hi Carolyn, Welcome!
Dave has some very pertinent questions.
If a water based impregnating sealer was used, there is no problem going over it with a solvent based impregnating sealer.
Either way your tiles aren't ruined, but they may need to be stripped if a water based topical sealer was used, and you want to change that coating to another product.
John Koessler
Unread 05-25-2012, 04:00 AM   #4
carolyn_haack
Thank you both!
The sealer was an impregnating sealer. The area is partially open to rain (covered porch, and then an open landing).
I had read somewhere that using an oil based sealer over a water based sealer led to greasy spots on the tiles and to flaking, and was concerned.
The tile is not shiny, as the oil based sealer is also impregnating.
Carolyn
Unread 05-25-2012, 05:00 AM   #5
Davestone
There may be some confusion.An oil based impregnating sealer is not an oil finish sealer.Although you can do it that way,just an impregnating sealer on tiles that get rain is a good idea.
The oil based sealer is a concoction of boiled linseed oil and a thinner usually turpentine,then it's usually waxed.This isn't a good setup for tiles exposed to rain.Neither is a topical sealer.
Unread 05-25-2012, 11:49 AM   #6
carolyn_haack
Dave,
Thanks! What would you recommend for tiles that are exposed to water? There doesn't seem to be a lot of people locally who know anything about working with Saltillo, and I'm getting some conflicting answers. Some of the websites I've seen recommend using an oil based sealer outdoors. But that may be for drier climates.
Carolyn
Unread 05-25-2012, 01:28 PM   #7
doitright
doitright's Avatar
Hi Carolyn
I see we're dealing with semantics here.
It is ok to use an oil based impregnating sealer outside. The one that I favor is SB Elements from STT. It is specifically designed for exterior use. PM me if you need additional information, as I am a STT Manufacturers Rep.
John Koessler
Oil vs Water Based Sealer rossmo Cleaning, Restoration and Sealing 4 08-11-2006 08:26 PM
Solvent/oil over water-based sealer on Saltillo eadmar Cleaning, Restoration and Sealing 3 06-12-2006 05:31 PM
Aqua Mix: Water-based sealer, over their slovent based sealer. Will it work? Mr.Heatmiser Cleaning, Restoration and Sealing 3 05-06-2006 02:16 PM
Saltillo~water/oil based seal?, baseboard ??'s ragdollx19 Tile Forum/Advice Board 3 03-19-2005 08:48 AM
Water-based sealer on top of oil-based sealer? Jenn Cleaning, Restoration and Sealing 8 08-29-2004 10:36 AM
