Unread 01-28-2020, 03:27 PM   #1
Pentheon
Bryan
Advice on stone fireplace.
Looking to redo our fireplace. Thinking about using stacked stone and then a floating mantel.
In the pictures you can see the upper half where the tv is set in the depth of 1 brick. Do you think it's ok to knock the lower half part that's sticks out further to make everything flush? The fireplace can function but we dont plan on using it and hasnt been used in years.
Thinking about just using furring strips from top to bottom then cement board. The last picture is an idea of what were looking to do
Any feedback or tips would be appreciated
Bryan
Pentheon is offline   Reply With Quote
Unread 01-28-2020, 04:23 PM   #2
Only way I know to determine whether you can safely remove the lower part of that facade, Bryan, would be to take out a couple of the upper bricks in the opening and see if there is a separate support for the upper section. It appears in one photo that there is a full brick extending back from the front face of the opening and I think it possible that could be part of the support for the lintel holding up the top half. That, of course, is just a guess.
One thing I would suggest is that you need to bring that hearth out far enough to meet code or somehow render the fireplace no longer able to be used for wood burning. At a glance it looks a bit shallow to me.
Unread 01-29-2020, 06:48 AM   #3
The upper section concerns me, Bryan, as it appears the mantle extends underneath the brick, and it also appears the brick isn't actually sitting on the mantle. Makes me wonder what's supporting the upper brick façade.
Unread 01-29-2020, 09:25 AM   #4
Pentheon
Bryan
I'm not sure, I assumed there was another layer of brick behind the lower half. There I'd another fireplace in the basement if that helps.
Here's a few more pics. Let me know if any other angles could help.
Bryan
Unread 01-29-2020, 09:55 AM   #5
We can see the usual 3x4" or 4x4" steel lintel supporting the brick face above the firebox opening, Bryan, but that still doesn't tell you what's supporting the upper brick veneer. I fully expect that upper veneer to be supported by a separate lintel of some sort above the damper, but I couldn't prove that without removing some brickwork.
Unread 01-29-2020, 10:20 AM   #6
Pentheon
Bryan
So do you think the safer option is to just add furring strips over the lower half out most part of the brick and just frame the upper half to be flush with the lower?
Bryan
Unread 01-29-2020, 10:36 AM   #7
If I knew I was gonna cover the face of the thing in any case, Bryan, I'd dig in there to see if I could remove the lower portion. Nothing to be lost to a little aesthetic damage if it turns out you cannot remove the lower portion and if you find you can remove it safely, you win.
Unread 01-29-2020, 12:11 PM   #8
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
What do you intend with the firebox proper? An insert of some kind? Use as is but with new face? If insert I'd want to know its depth so I didn't remove façade only to find out I need the depth for it to insert into. Your downstairs flue likely runs behind or to the side of the one we're seeing. It's gonna be a massive chunk of masonry no matter what.
Flammable fur-out of bottom would be bad idea if close to firebox. Were it me and from what I can see there in photos, I'd be inclined to remove or cut that end facing top course of bottom section, and fur the top out. Seems like it would be simplest all things considered. Maybe you don't want that depth in the new façade?
Some photos of how the mantel intersects brick might be insightful. It's outside of the ordinary, at least for this neck of the woods.
Peter
Unread 03-22-2020, 09:46 AM   #9
Pentheon
Bryan
Sorry for the late reply.
Honestly not too sure what I had planned for the inside. Possibly an insert maybe like you said depending on the depth if able too. If not maybe just paint or something to make it look fresh or a stone if possible? We honestly don't plan to use the fireplace.
The main reason i want to cut back on the bottom if i can is to gain as much space as possible. The living room is long but not wide so with the couch on the other end of the fireplace I dont wanna fur the top out and the tv stick out too much and somebody hit into it
Bryan
Natural stone on Fireplace and hearth stone setting? Elkski Tile Forum/Advice Board 3 02-28-2017 12:12 PM
Stone around a fireplace jaguar Tile Forum/Advice Board 14 06-25-2008 09:33 AM
Need advice on Natural Stone Fireplace surround Burke757 Tile Forum/Advice Board 7 02-01-2008 12:20 PM
Fireplace stone Carolej Tile Forum/Advice Board 3 02-04-2006 11:48 PM
stone fireplace pelon Tile Forum/Advice Board 2 11-17-2003 02:24 PM
