OK, now that I know that you have your liner in place, it's a little late for Kerdi (
www.schluter.com).
Kerdi showers are a complete system which includes a special drain, but does not include a PVC or CPE liner. Also, it is a relatively new system, so some juristictions do not recognize it yet, so building inspectors have to be trained before they'll sign off.
I agree with Mike and Jerry, a monument bench is your best choice now. The mass of the bench is enough to keep in anchored in place. Plus, when you tile it, you will further lock it in.
Although the benches are usually built directly on the liner, you could build it on top of the setting bed, if you are worried about tearing the liner.
The beauty of the monument bench is that it sits completely within the pan, and is impervious to water, so there is not chance for rot. The down side is that they can absorb water, so they take longer to dry out.
Take another look at the Shower Construction thread in the Liberry. Then come back with anything that doesn't make sense to you.
