The beginning of this thread is from a previous inquiry. I included it here because I had comments plus more follow-up questions. I’m afraid many more may follow. How do I keep this internet thread current as I’ve seen in other threads. I apologize for my ignorance in the matter.
**************The New Stuff*********
Thanks Davestone, opiethetileman (Can I call ya Op?) and John-
All good advice.
Good point Davestone but it's tight (36" width overall to work with) and I'd love the extra elbow room. (I use to smack ‘em (elbows) all the time in the old shower enclosure.) And you brought up an issue you could advise me on. I was considering the possibility of placing the shower glass walls as close to the outside edge of the curb as possible to steal what room I could. Is this a no no, structurally. I figured as long as I kept them directly over the wood 2x4's, they'd be just as supported as if they were in the center of the 2x4's. I don't feel visually they will look bad but I haven't seen them either. What do you think?
Op, I've been fairly assured by using the Kerdi membrane, water is not gonna be an issue for anything under it. Do you have a concern even with the using of Kerdi?
So I think I'll go with John's 2x4 curb idea which is a fair compromise. You did mention in your book you liked using 2x4's on end for a unique look, if I remember correctly. Maybe that can be done but Op' stability comment seems a valid one which may stop that idea considering the possible weight impact of the thick shower glass door and walls. And my desire to place them on the outside edge of the curb as mentioned earlier to Mr Davestone. What do you think, John?
Another question guys if I may. I'm fairly sure I know the answer from all my research but I still feel considerable qweeziness about. I have researched: "It's OK to use Kerdi on greenboard and drywall" And as I've gathered, it's Drywall or Greenboard, thinset, Kerdi, thinset, tile, grout, sealer. My concern is the 2 thinset layers do not provide the stability you would get if you were to put those 2 layers on traditional CBU or even the Hardi Backer or DuRock type backerboard. Even tho, I've learned the thinset is expected to be uncoupled from backerboard anyway. (I suffer from the "more is better" mentality.) Everything indicates, tho, those 2 layers combined with tile are as strong as one may need to succeed with a long lasting tile job. -Correct or did I fail miserably in my studies? Again, Thanks for your time. - Dale
Little more background on what I’ve gone with so far based on my internet learnings. Mostly from this web site. I’ve deemed John an authority. Jump to string of asterics below if this doesn’t help or interest you.
Reason for fix, Fiberglass type shower pan cracked and leaked at drain rim which resulted in adjacent particle board under linoleum to swell.
I have ripped up all particle board. ( Wwwhy in a bathroom? ) Left with 3/4” plywood subfloor on 2x6 (5 1/2”) joist, 16” oc. Checked deflection rate on your site, Great thing you provide. (I sound like Yoda)
Added 3/8” plywood “sheathing rated” (hope that’s good) using subfloor rated adhesive smoothed out to avoid voids and screwed down with 1 1/8’’ deck screws. Gave approximate 1/8” expansion gap at all plywood butts and 1/2” gap on room perimeter. Polyurethane chalk applied to 1/8” expansion gaps.
Utilized self leveling cement for low point near plywood replacement area and all screw depressions for both subfloor and added plywood.
Made tub surround for drop in acrylic deep soaker type tub, no jets.
Another question is do you see any issue with my tub surround not having cbu or plywood “skin” as its “joining” surface for the first layer of thinset and kerdi. I’ve made the surround with solid 2x4’s on the top side of the surround ( small deck ). At points and spans I’ve flatten and leveled as needed using self leveling cement.
I got the impression early on that slc was acceptable for thinset underlayment.
I’ve base this construction decision on my research of Ditra’s ability to be applied to plywood subfloor with SLC in the same manner. The 2x4’s are much more stable and, I feel, are just a viable.
I’ve been getting the feeling it’s always adhered to cbu or plywood and it’s the flatness factor thats warrants that. I feel I achieved that anyway with my 2x4’s and self leveling cement. Do you feel I should be OK or did I make a mistake somewhere in my assumption that this would work.
Also, I’m constructing a shower seat in the same fashion as the tub surround. 2x4’s and SLC on the horizontal plain. A fiber CBU will be used on the larger vertical plains. I find nothing about wood construction for shower seats which leaves me with concern. With you concurrence, I feel confident if I overkill it with double and triple layers of 2x4’s using deck screws and subfloor adhesive to the wall studs and upgraded subfloor, it’s not as good as a John Bridge “monument”, but more than adequate. -John????
Davestone, thanks for your jamb wall explanation. Your “jutt out” phrase made me see it. If I’m correct, this is a wall coming off another wall at 90 degree angle to form a portion of the shower enclosure that the curb would grow off of.
Many Thanks, Guys!! Dale
