Thanks for the quick reply.
1) I'll scrape the black rubbery stuff, apply the thinset on top of the apparent asbestos tile. The previous floor installer scraped the asbestos tile in the portion under the refrigerator, about a 3 x 3 ft area. Do you think the combination of the thinset and the CBU will compensate for the unevenness between the scraped and unscraped tile?
I assumed the lowest layer of tile was asbestos because it was installed in 1969 and is held with incredible tenacity by the cutback. For piece of mind I'm planning on calling an asbestos testing company tomorrow to check. The tiles in question are 12inx12in and very hard when you tap them. At first I thought they might be ceramic till I noticed they were so thin. Can anyone say based on that description yeah, or nay as to whether they are asbestos or do they need to be tested?
2) The joists are 16" oc. The unsupported beam is length is 62.5 inches. The beams are 2 x 9s.
From the top, beneath the tile & cutback: 3/4" plywood, 1/2" plywood for conduit, 1/2" plywood.
Without consulting a building code or TCA handbook, it seems that this is a pretty solid surface. Once the rubbery material is removed the plan is to thinset, cbu, check for level, use SLC if necessary, and lay tiles.... sound cool?
