Welcome to the forum, Z.
I assume you're referring to the horizontal seam about five feet up from the tub, is that correct?
Two problems you've got there. First, you used Hardibacker, which is a little thinner than 1/2" sheetrock. Second, the sheetrock at that point is usually thicker because where is terminates at the top of the fiberglass tub/shower, (that's what you had there, right?) the sheetrock is taped and mudded, typically.
Those two things are the reason I always just take out the wall board to the ceiling. So that's what I would recommend you do at this point. Cut it at that joint and use Hardibacker to the ceiling.
You don't have to waterproof it if it's above the level of the shower head, just tape and mud the seams.
