Unread 04-10-2019, 10:09 AM   #1
shawninvancouver
shawninvancouver's Avatar
How to Clean this or do i need to re tile??
Not sure what this is? mould? stains? etc.. the tile is porous.. it was sealed.. there are no leaks...
its very strange, only on one wall of the shower... tile under the shower head that gets most of the water is fine.. its around 8 -9 years old..
i have tried to dry it out and re seal it.. they keep coming back when wet..
what can i do??
bleach? any ideas??
thanks
- No Tile Pro here...
shawninvancouver is offline   Reply With Quote
Unread 04-10-2019, 12:24 PM   #2
shawninvancouver
any help here???
Unread 04-10-2019, 01:28 PM   #3
claycarson
Commercial Cleaning and Maintenance
Shawn,
Manmade tile or natural stone?
Try 50/50 bleach and water spayed on so it has 10-15 minutes of soaking time.
If that reduces the marks dramatically, then it was mold stains. Pretty common in this setting.
Post afterwards so we can follow up.
Sent from my SM-G920T using Tapatalk
Clay
www.tileboston.com
claycarson is offline   Reply With Quote
Unread 04-10-2019, 01:29 PM   #4
claycarson
By the way, bleach won't hurt stone or grout, we use it all the time
Clay
www.tileboston.com
Unread 04-11-2019, 07:56 AM   #5
shawninvancouver
Yes, natural stone and porous... but can bleach still get in to clean it if the tile was sealed??
Unread 04-11-2019, 02:46 PM   #6
shawninvancouver
Yessss.. natural stone and soaks water in it.. its not ceramic.. but im sure it was sealed when originally done.... willl the bleach get in there to whiten it??
Unread 04-11-2019, 06:36 PM   #7
claycarson
Shawn,
Not sure, worth a try. If it misses some spots, then you'll know.
The most common type of sealer, penetrating sealer Is not a thick topical film, it's absorbed inside the stone. It allows vapor transmission so it may allow bleach to get the mold stains.
Won't cost a lot of time or energy, so no reason not to try .
Clay
www.tileboston.com
Unread 04-12-2019, 02:03 PM   #8
JohnnyPronto
I would test different chemicals, one tile at a time.
John
JohnnyPronto is offline   Reply With Quote
Unread 11-11-2021, 12:36 PM   #9
shawninvancouver
looks like a dark blotchy pattern over the tile.. its a natural stone ( bad idea )
i have tried some basic cleaners but is there a trick to get it gone?? some cleaner i leave on or something??
any ideas??
thanks
Unread 11-11-2021, 04:21 PM   #10
shawninvancouver
any ideas here?
Unread 11-11-2021, 04:44 PM   #11
Welcome back, Shawn.
Might need to be a bit more patient 'till the right people see this.
I combined you with your same question a couple years ago. Chances are good you'll get the same responses, but hang on, I been wrong before.
Unread 11-12-2021, 08:24 AM   #12
Looks like moisture is getting behind the tiles based on the front ledge of the niche. If that’s the case, sealing it is making things worse because it can’t dry out. But before we go too far…
1) What method of waterproofing do you have with the shower?
2) Did the bleach do anything?
3) Has there been a cleaner that’s made any improvement?
4) Have you used any high-alkaline cleaners?
5) How are you applying the cleaners? Just spraying on and immediately wiping off? Or are you allowing it to dwell for a few minutes?
6) Are you using bar soap instead of liquid soap?
Unread 11-12-2021, 10:18 AM   #13
shawninvancouver
can this be cleaned or do i need to re tile?? it could be mold like.. it disapears when the shower dries.. will bleach or vinigar or some home depot stuff get rid of it??
help me!
Unread 11-12-2021, 10:53 AM   #14
Shawn, starting new threads with duplicate questions is not helpful here. I've combined you with the original thread and invite you to view the recent response.
Unread 11-12-2021, 06:12 PM   #15
A couple of things you might try...no guarantees!
IN addition to what's already been suggested, you might try Moldex solution. I tend to order it from Home Depot, as they seem to have the best price on a concentrated gallon, which lasts me usually at least a couple of years. I use it to clean the walls in my shower, and let it soak in the air tub's passages to manage the mold that likes to grow in the dark, moist passages.
There's a mix your own solution whose recipe I read here years ago that some swear by. A search should find it, but if I remember, it contains the following, but don't remember the concentrations:
- hydrogen peroxide
- methanol alcohol
- borax
- water
Again, this is from memory, so may be off a little: the H2O2 acts like a bleach, the alcohol works as a solvent, the borax shreds the cellular walls of the mold spores, and the water helps it all to flush it away.
Natural stone in a shower can be risky for the reasons you're seeing. A much less porous ceramic look-alike is often the better choice.
How to clean this tile??? loves2read Cleaning, Restoration and Sealing 6 09-30-2016 08:32 PM
How clean do you set tile? Higher Standard Tile Professionals' Hangout 88 05-04-2014 07:48 PM
A Clean Cut on Tile DieselDennis Tile Forum/Advice Board 2 01-15-2012 09:11 AM
What do I clean my tile with? bigcaat Cleaning, Restoration and Sealing 1 11-17-2006 03:45 PM
clean new tile help... milwaukeeiron Cleaning, Restoration and Sealing 5 05-13-2005 04:51 PM
