Unread 02-14-2009, 07:43 PM   #1
lyu370
Cutout in porcelain tile
OK, I'm stumped. Putting in some porcelain tile in a bathroom. Trying to cut a cutout for a register in one of the tiles and I'm having no luck whatsoever. Trying to cut a 4 1/2 x 10 cutout for a register in a 12" tile. Using an angle grinder with a diamond blade, but the tile keeps cracking. The cutout is about 2" from one edge, and about 1/2" & 1 1/2" on the other two edges. Already snapped three tiles, which I can still use along the walls.
But how do I make the cut? It's driving me nuts!
Long time lurker, finally need some advice.
Thanks.
Andy
lyu370 is offline   Reply With Quote
Unread 02-14-2009, 08:03 PM   #2
muskymike
muskymike's Avatar
Hi Andy, welcome! You will most likely need to cut the tile onna wet saw. Some porcelains just blow out when you try to cut them.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 02-14-2009, 10:30 PM   #3
are you using Marazzi from home depot ?
I have the worst luck with small cuts with that stuff.
great tile but breaks all over the place.
Unread 02-15-2009, 06:54 AM   #4
cleveman
At some point, especially if you don't want to get a wet saw, you may have to just piece it in.
When you get down to real narrow pieces holding together a big piece, it is just not feasible. Imagine you wanted to cut a piece and leave a 1/2" strip holding it together.
Anything is possible, but if you don't want the aggravation, just cut it up in pieces and observe your regular joint widths and go with it.
By the way, you can pick up a cheap wet saw at the big box stores probably for < $80.
cleveman is offline   Reply With Quote
Unread 02-15-2009, 08:26 AM   #5
Hammy
Hammy's Avatar
Take it to BIG BOX store, get them to cut it. ( take an extra tile with you ) Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 02-15-2009, 09:23 AM   #6
lyu370
The tile I'm using is American Olean, got it at Century Tile. I do have a wet saw, works great for the straight cuts, guess I'm just not sure how I'd use it to make a cutout.
Unread 02-15-2009, 02:57 PM   #7
Hammy
Hammy's Avatar
give us a drawing of what youre trying to do. That might help us to instruct ya. Hammy
Unread 02-16-2009, 03:12 AM   #8
oogabooga
Hmmm, from what you describe I'm wondering whether it can actually be cut without breaking. Guess it would depend on how cantankerous the tile happens to be
Cleveman's suggestion might be the easiest solution, but if you can't live with that (aesthetically speaking), you could try making the rest of the cut on the broken tiles and glueing them back together with clear epoxy. Worth a shot maybe?
Rob.
oogabooga is offline   Reply With Quote
Unread 02-16-2009, 03:44 AM   #9
Aquera
Air Filter
Aquera's Avatar
there's a few things you can try - first use the angle grinder but don't cut all the way through on the first pass, try a few passes. Also make a relief cut down the middle and accross the area that's getting cut out - if the tile is going to break, it will tend to break in the direction of te area you've weakened.
you can use your wet saw, even if it doesn't do plunge cuts - you either need to remove the splash guard, and drop the tile down (you'll get wet) or if you aren't cutting a hole in the middle, you can simply just make a bunch of straight cuts, about blade width apart, and then break off the little pieces...
Aquera is offline   Reply With Quote
Unread 02-16-2009, 10:30 AM   #10
MudGuy
Pass the Mud
MudGuy's Avatar
Andy –
Some porcelains are too hard, and taking the cuts that close to the edge, they’ll snap. I had the same situation, snapped five of em’, bought a new 4” blade, snapped two more…hard headed. I ended up marking a full tile, installing it over the register duct, allowing it to dry for several days before cutting it in place. Worked great…until a couple days later, I noted a very small hairline crack.
Jonathan
MudGuy is offline   Reply With Quote
Unread 02-16-2009, 10:43 AM   #11
Rd Tile
Tile Man
Rd Tile's Avatar
Take your time with the grinder, don't force the issue, almost make the cuts with the just the weight of the tool doing the work, go SLOW.
Richie.
Unread 02-16-2009, 10:50 AM   #12
Your register will cover most of the tile, so if you piece it, very little of the joints will show.
Porcelain tile made in Spain weight question ruben7566 Tile Forum/Advice Board 1 05-22-2006 01:37 AM
Any Tips for Laying 18*18 Porcelain Tile papitojr Tile Forum/Advice Board 8 05-17-2006 06:23 AM
Ditra/porcelain/unmodified vs modified thinset Jeff_kitchen Tile Forum/Advice Board 312 10-19-2005 10:29 AM
Porcelain tile help coralbayresident Cleaning, Restoration and Sealing 5 10-19-2005 09:12 AM
glazed porcelain tile Michaela Tile Forum/Advice Board 4 01-24-2005 09:15 PM
