Unread 10-21-2017, 12:10 PM   #1
smvatter
Master Bathroom Remodel
Hi All
I am in the process of having master bath remodeled. I noticed after the shower floor was grouted that that the 2" white Carrera hex marble had turned gray. It seemed to get worse after plumber installed showed head and body jets and was testing water.
I will tell you the tile installers that GC used this is not only area of concern they made big mess of complete install. It was as if I did my own tile work
The is a slope in the shower going to the drain, almost feels like your in a small hole, which I thought was kind of weird. Also darkening seems worse at the back of the shower on my right if I was facing shower head.
Given that remodel is still in progress these tiles have not been sealed and I will tell you the tile guys did awful job with the grouting.
Right now I have some of surplus in water to see if it turns gray.
Any advice will be greatly appreciated. As this has been long road from dealing with insurance company last Feb 3rd, 2016 to finally getting bathroom repaired to have it go so wrong
Kind regards,
Sharon
Sharon
Last edited by smvatter; 10-21-2017 at 01:09 PM. Reason: attaching additional image
smvatter is offline   Reply With Quote
Unread 10-21-2017, 12:47 PM   #2
rmckee84
rmckee84's Avatar
Marble is a poor choice for wet areas. Many times there will be discoloration once water is introduced.
Ryan McKee
Unread 10-21-2017, 03:04 PM   #3
Tiger Mountain Tile Inc
There's two issues: the marble getting dark and the way the shower is built.
In regards to the marble darkening this is just what's going to happen. If you don't want dark marble then you'll have to go with a porcelain tile that looks like marble.
The way your shower is built is cause for concern. The bottom where the liner goes into the wall isn't correct. Also, where it wraps into the curb is probably the most alarming.
This thread in the Liberry is a good resource on shower construction. It's wise to bring up the issues with the general contractor and let them know that you want your shower built correctly to industry specifications.
It might be wise to change your shower pan tile in the process.
Jim Upton
New DIYTileGuy blog post: Flood testing a shower pan: Why it's done and how to do it
Unread 10-21-2017, 05:14 PM   #4
smvatter
Hi Jim
Thank you for your response. Can you explain further when you are talking about the shower membrane being most alarming over curb. Will this now be a potential for water leak or drainage issues.
Sharon
Unread 10-21-2017, 07:52 PM   #5
The bathroom floor tiles run right to the edge of the shower, which is fine. But it looks like they stuck half of the tile to the concrete slab and the other half to the pan liner. Not sure that's what they did but they may have. Also, what did they stick the tiles to on the inside of the drop down, between the edge of the step down and the shower floor?
You're not supposed to stick tiles directly to a PVC pan liner.
I like seeing the glue on pan corners and I'm not seeing them. The "shower construction info" thread shows what I'm talking about. That thread is in the "liberry" (dark blue bar above).
Unread 10-21-2017, 09:07 PM   #6
smvatter
Hi Davy
That's a very good question that I can't answer but will certainly ask.
I did send a message to BuildersDepot where I got the tile and they said that they should have sealed the tile before it was grouted since it was natural stone. They also mentioned it could be issue with thinset vs. mastic. I noticed in my bedroom where they have all their supplies the bag of Versabond is white but is says not for stone.
Will have lots of questions for GC come Monday.
Sharon
Sharon
Unread 10-21-2017, 09:24 PM   #7
rmckee84
rmckee84's Avatar
Sealed or not discoloration is likely with that tile. Versabond is what I would call builder's grade thinset. It isn't bottom of the barrel but its far from quality material in my opinion. The bigger issue would be if they had used grey instead of white, that would have really shown.
Aside from the discoloration, like others mentioned you should definitely have a talk with the installer and figure out what exactly they have going on there...
Ryan McKee
Unread 10-22-2017, 09:04 AM   #8
What I mean is where the liner goes over the curb. There should be corner piece that gets put on the corner and flashes up the wall. I'm fairly certain that yours doesn't have that. It's one of the most common places for a shower to leak.
This is an example of the corner and some more information.
(2nd photo of the slider)
Jim Upton
Unread 10-22-2017, 09:49 AM   #9
smvatter
Hi Jim
Your correct. I never saw one of those like when I would go in to take pictures after they would leave at night.
There are so many things wrong with the tile work that the GC's sub did in the entire bathroom.
Its so disappointing. You trust that GC who was very highly recommended would bring in professionals and to have the entire job be a complete train wreak.
The extra marble tile that I soaked overnight remained in its original state - white and did not turn gray. So leads me to believe something to do with the shower pan or thinset as you all have mentioned.
Appreciate all the guidance,
Sharon
Sharon
Unread 10-22-2017, 03:01 PM   #10
This should be brought up from the tile contractor and at the tile store where the tile was selected from the very beginning. Then you know there's a chance the color could change.
KS Master bathroom remodel mstbone67a Tile Forum/Advice Board 41 01-09-2018 09:12 PM
Stu's master bathroom remodel Stu27 Tile Forum/Advice Board 13 10-28-2011 01:52 PM
master bathroom remodel dizzyj Tile Forum/Advice Board 29 11-09-2009 11:10 AM
Another Master Bathroom Remodel(er) WadeE Tile Forum/Advice Board 15 11-02-2009 09:36 PM
Tae's master bathroom remodel dontnomuch Tile Forum/Advice Board 91 03-18-2009 11:38 PM
