Unread 01-08-2012, 07:36 PM   #1
Tom prochoren
Hardiebacker walls over hotmop pan
What is the best way to install hardiebacker on walls over hotmop shower pan? Will I have to shim 2x4's and remove about 1/8"from bottom 10" of 2x4's?Do I need to remove any thing from sill plate? Thanks all info will help.-----Tom
Tom
Tom prochoren is offline   Reply With Quote
Unread 01-09-2012, 05:28 AM   #2
Shimming will be the easiest solution for you. The hot mopppers may not be able to gage the thickness as well as you would hope.
Remember not to nail the backerboard below a line that's at least 3" higher than the curb.
Unread 01-09-2012, 07:31 PM   #3
Tom prochoren
Thanks Bob. What is the best way to attach bottom 10 or 12 inches of hardibacker over hotmop?
Tom
Unread 01-10-2012, 08:42 AM   #4
Hi Tom,
The bottoms of the boards are not attached. They can be held in place with the deck mud floor you will install later.
Hot mopped showers are usually mudded up the walls. It's not that easy to use backer board, but it can be done, of course, by shimming.
Kerdi Shower Install with HardieBacker Walls mike99 Tile Forum/Advice Board 3 01-01-2009 05:57 PM
Help! cutting hardiebacker to fit curved walls teehee Tile Forum/Advice Board 2 10-12-2006 05:57 PM
Can I Repair a Damaged Hotmop Shower Pan? GWB Tile Forum/Advice Board 5 05-15-2006 12:04 PM
Hanging Hardiebacker and tiling walls - leave 1/8 gap or not? WEEKEND BUILDER Tile Forum/Advice Board 3 04-25-2006 10:42 PM
Resolving Greenboard overlap on Hotmop Pan GWB Tile Forum/Advice Board 5 04-14-2006 11:19 PM
