Unread 10-24-2019, 10:57 AM   #91
You can get an after-market flange and continue the existing one around the corner and to the floor.
I had to buy one online a while back, they're pretty easy to install, but it's best to install it and leave it for a day to let the silicone dry.
I would make sure the lumber is behind the area where the new flange will go. They're pretty flexible, and need some backing for support.
Unread 10-24-2019, 11:50 AM   #92
When attaching Kerdi to something like a tub flange, KerdiFix is probably the better choice. The stuff sticks to nearly anything and is quite durable. It isn't a finishing material that silicon can be, but is a better adhesive.
Unread 10-25-2019, 08:05 AM   #93
JWOrl
Thanks Kevin....do you mean something like this:
https://www.homedepot.com/p/Comfortf...E&gclsrc=aw.ds
The other ones I saw online were all about $150 and there's no way I want to pay that much for this. Thanks.
John
JWOrl is offline   Reply With Quote
Unread 10-31-2019, 01:22 PM   #94
JWOrl
I'm not sure if I made a mistake...I removed part of the stud (see photo) because it was rotten in some parts at the bottom).
I was going to fit it with a new partial stud (see photo), securing it with mending braces and toenailing it at the bottom, and then attach a sister stud to the left of it.
But then I was thinking -- if two different pieces of wood are attached vertically as I want to do, will they flex or expand and contract at different rates and amounts -- could it cause future problems with the tile and the boards?
Completely removing and replacing that stud may be difficult because as you can see in the photo there is a small header on top and I think because of the tight space it may be difficult to remove this and reattach the header.
This is a non-load bearing wall.
What would you do here? thanks.
John
Unread 10-31-2019, 01:39 PM   #95
Red face
I wouldn't have cut the stud, but rather put one right next to it.
It'll be fine with a sister attached. Don't over-think things.
Unread 10-31-2019, 01:45 PM   #96
JWOrl
OK thanks, I'll just stick that new half piece in and then sister a stud next to it.
John
Unread 11-01-2019, 05:43 AM   #97
Whatcha gonna do with that other cut off stud, John?
Unread 11-01-2019, 07:28 AM   #98
JWOrl
for the other one...i was going to basically do the same thing...sister a stud and toenail it and then attach a piece under the original with cutouts for the plumbing so that something is there.
John
Unread 11-04-2019, 06:27 PM   #99
JWOrl
The stud in the center with green tape on it "twists" very slightly (not sure if you can tell from the photo)...I measured at different points and there is a variation of about 1/4 inch at various points between this stud and the one next to it...
1) Is it safe to use this stud for the hardiebacker or do I have to sister stud this one? This is a load bearing wall and I'm a little nervous about the idea of removing and replacing the original.
2) When you do a sister stud is it required to toenail (from one side, at least) at the bottom and top or is screwing/nailing from just the sides of the new stud sufficient?
John
Unread 11-04-2019, 07:25 PM   #100
A bit of bow in that direction is not a problem at all, John, so long as the stud face is straight and in plane with its neighbors.
When sistering studs for non-structural purposes, you can usually get by just fastening the sister to the existing. I would likely toe it into the plates, but it's really not necessary in most cases.
Unread 11-05-2019, 06:13 AM   #101
JWOrl
Great...thanks CX!...what a lifesaver this place is.
John
Unread 11-05-2019, 06:56 AM   #102
Right?
You might consider letting (recessing) those nail plates into your studs, John. Leaving them proud of the stud face will result in a hump in your wall board, which I think will be noticeable so close to the top of the tub.
Also, be sure that nail plate in left corner isn't rubbing on your PEX supply lines.
Unread 11-05-2019, 09:06 AM   #103
JWOrl
Thanks Dan...the plates are recessed now (don't if you can tell from the photo). I used a chisel and dremel. But I'll double check to make sure I didn't miss any.
John
Unread 11-07-2019, 08:02 PM   #104
JWOrl
What do you guys think about grout color choice? I wanted to use a gray grout (also planning to paint walls gray) to give the white subway tiles some contrast but someone said using a non-white grout will show any errors in the tile layout, etc...is this a serious concern or will my plan work? Thanks.
John
Unread 11-08-2019, 07:37 AM   #105
Someone is correct, John, contrasting grout colors will tend to make any irregularities in tile setting more visible. The higher the contrast, the more visible. IMO, I think a very light gray grout with those white SW's would look great, refined even, without being too contrasting.
Grays can be tough, I struggled with mine.
Is it okay to mix durock and hardiebacker together on adjacent walls? fredhead Tile Forum/Advice Board 21 08-31-2012 11:19 AM
Hardiebacker walls over hotmop pan Tom prochoren Tile Forum/Advice Board 3 01-10-2012 08:42 AM
Kerdi Shower Install with HardieBacker Walls mike99 Tile Forum/Advice Board 3 01-01-2009 05:57 PM
Help! cutting hardiebacker to fit curved walls teehee Tile Forum/Advice Board 2 10-12-2006 05:57 PM
Hanging Hardiebacker and tiling walls - leave 1/8 gap or not? WEEKEND BUILDER Tile Forum/Advice Board 3 04-25-2006 10:42 PM
