Unread 04-29-2020, 06:50 AM   #226
JWOrl
Thanks Dan. The water idea sounds good.
John
JWOrl is offline   Reply With Quote
Unread 04-30-2020, 09:20 AM   #227
JWOrl
I called Custom Building Products to ask about what proportions to make the primer mix of Redgard + water because I wasn't sure of the proportions.
The guy told me they no longer recommend that for Hardiebacker and that I should use MBP (Multi-Surface Bonding Primer) as the primer instead.
I've never heard of this product. Are they just trying to make money by pushing a product that is unnecessary? Has anyone here used it? Any advantage over the water/Redgard mix?
https://www.homedepot.com/p/Custom-B...MBP1/205486856
John
Unread 04-30-2020, 10:45 AM   #228
John,
We always defer to the manufacturer's instructions. Yes, sometimes it can look like they are trying to sell more product, or justify the paychecks to the guys in R&D, but regardless we are bound by the manufacturer's instructions as they reign supreme in court and in our industry.
Now some folks will say "I've done that for 30 years..."
Unread 05-13-2020, 04:08 AM   #229
JWOrl
Thanks Houston. I ended up buying a countersink bit and using the screws.
I have to say I'm not thrilled with the Hardiebacker product so far, it has a lot of quirks that James Hardie doesn't bother to address in their instructions. And I've also found several boards with defects -- bowed, or big lumps on the surface.
John
Is it okay to mix durock and hardiebacker together on adjacent walls? fredhead Tile Forum/Advice Board 21 08-31-2012 11:19 AM
Hardiebacker walls over hotmop pan Tom prochoren Tile Forum/Advice Board 3 01-10-2012 08:42 AM
Kerdi Shower Install with HardieBacker Walls mike99 Tile Forum/Advice Board 3 01-01-2009 05:57 PM
Help! cutting hardiebacker to fit curved walls teehee Tile Forum/Advice Board 2 10-12-2006 05:57 PM
Hanging Hardiebacker and tiling walls - leave 1/8 gap or not? WEEKEND BUILDER Tile Forum/Advice Board 3 04-25-2006 10:42 PM
