Unread 08-27-2010, 08:49 AM   #1
Looking4ideas
Composite concrete shower base
Hi, everyone -- We're about to set a composite concrete shower base (seen here: http://www.alcove.ca/en/nosproduits.php?cat=1) and the instructions are less than detailed. It says to use a mortar base to set it -- should we use thinset? Thanks for any advice you can offer!
Barb, Toronto, Canada
Looking4ideas is offline   Reply With Quote
Unread 08-27-2010, 09:26 AM   #2
Lazarus
Lazarus's Avatar
Their installation picture shows a rather thin bed under the base so I would assume that a "thinset morter" would be satisfactory.
Unread 08-27-2010, 11:28 AM   #3
Looking4ideas
Thanks, Lazarus. Do you think we should use modified or unmodified thinset?
Unread 08-27-2010, 03:30 PM   #4
Lazarus
Lazarus's Avatar
I would probably use something like Home Depo's versabond. Having said that, I'm sure you could also use the "Sand Topping Mix" from the brick & block section.
Wet the floor with a sponge and underside of the receptor...lay in a bed of thinset a bit higher than the underside and place it. Add some weight to fully "bed" it and you should be good to go. Another option that I use under tubs is the spray-in expanding foam. If you go that route, use the heavy-duty stuff....set the receptor and spray it under it with some weight on it. Don't go crazy with the spray....just enough to fill and support.....
Unread 08-27-2010, 03:47 PM   #5
Looking4ideas
Thanks, Lazarus. This thing isn't hollow, though -- it has a flat bottom. And it weighs a ton! Do you think undmodified thinset, mixed to the manufacturer's specifications, will work just as well?
Unread 08-27-2010, 04:00 PM   #6
Lazarus
Lazarus's Avatar
I see no reason why not. Mix it to the consistancy of loose "peanut butter"...just wanna be sure it fills all the voids beneath it.....
Concrete Shower Base jak10 Tile Forum/Advice Board 7 04-29-2010 08:27 PM
Shower pan on concrete base TheWardensWorker Tile Forum/Advice Board 8 08-29-2009 09:16 AM
Does a composite shower pan need liner? pgabriel Tile Forum/Advice Board 3 11-07-2005 04:01 PM
repairing concrete shower base bhthomas Tile Forum/Advice Board 10 04-30-2004 12:37 PM
Concrete Shower Base PRZ Tile Forum/Advice Board 3 02-07-2003 09:27 AM
