Unread 11-07-2005, 10:19 AM   #1
pgabriel
Does a composite shower pan need liner?
Hi All,
I plan on installing a swanstone (composite) shower pan. Their limited installation instructions, don't really depict whether or not I should use a 40 (or so) mil liner, then place the pan on it.
(Using wonderboard CBU for walls and tiling from the ceiling all the way to the
shower pan on a 3 wall surround shower).
Advice welcome.
pgabriel is offline   Reply With Quote
Unread 11-07-2005, 01:08 PM   #2
Viper
No
Viper is offline   Reply With Quote
Unread 11-07-2005, 02:42 PM   #3
But you do need a moisture barrier behind the CBU on the walls.
Unread 11-07-2005, 04:01 PM   #4
pgabriel
Thanks Bob. I do have 15lb roofing felt for over the studs and behind the CBU. Just looking at the drain, I couldn't realistically see how it would be leak proof ala the Kerdi system.
